Old 10-16-2006, 07:31 AM   #16
Muller Chevrolet
Fav Mod: a new 09 STi
IWSTI Addict since: Oct 2004
exactly.
they are built a lot simpler than cobb's, so what i mean is when you have to lube them it's mad easy....as soon as you get them you will see what i mean and you'll see what you want to lube, which you should do before you install.
my cobbs were quiet right of the bat, but i was mad abou the hardware..
kartboy uses a different nut that locks onto the bolt more and mine haven't come loose yet.
i tightened them to like 35 and kartboy recommends 40 i believe...cobb wanted theirs at 31-32, which is like the stock ft/lbs yet isn't enough to keep them on and overtorquing isn't recommended.
VSGTS14 is online now   Reply With Quote
Old 10-16-2006, 07:59 AM   #17
Car: RIP 02 WRX
IWSTI Addict since: Dec 2005
Just go with the KBs from TiC and forget about it. Endlinks really shouldn't be this big of a deal.
Old 10-16-2006, 08:41 AM   #18
Car: 04 WRB
Fav Mod: Greddy TI-C
IWSTI Addict since: Jan 2006
KB endlinks and while you are there, get the TIC fender braces, they are supposed to work wonders from what i have read
Old 10-16-2006, 09:14 AM   #19
Car: RIP 02 WRX
Indeed. TiC puts together some pretty nifty package deals.
Old 10-16-2006, 12:54 PM   #20
Fav Mod: Starving my STI
IWSTI Addict since: Sep 2006
Trader Rating: (15)
Correct me if I'm wrong, but I thought it was the WRX with the weak braces and the STi already came with pretty good fender braces from the factory?
Old 10-16-2006, 01:03 PM   #21
Car: RIP 02 WRX
You're wrong. The stock STi braces are flimsy stamped steel.
Old 10-16-2006, 01:04 PM   #22
Car: 2005 STi
IWSTI Addict since: Jun 2005
I have the Kartboy rear; they are silent just as the stock. Never had one problem with them.
Transworld is offline   Reply With Quote
Old 10-17-2006, 07:59 AM   #23
Car: 04 WRB
Stock vs GT spec complements of Bruce Chapman
TIC vs Stock complements of Subiegal
Old 10-17-2006, 08:27 AM   #24
Car: RIP 02 WRX
nice post PSuLemon.
Old 10-18-2006, 06:02 AM   #25
Car: 04 WRB
Originally Posted by LOLSTi
nice post PSuLemon.
Thanks, my only concern would be with the GTspec but its probably since i haven't research it too much. Your greatest strength will come from something that has less bends. But I am off to research to see if the GTspec design is optimum or not.
Old 10-18-2006, 06:14 AM   #26
Car: RIP 02 WRX
Yep. TiC ones are at the correct pricepoint, and simplicity of design, IMO.
Old 10-22-2006, 12:40 PM   #27
Car: 2004 STI
IWSTI Addict since: Apr 2004
I'm getting the COBB swaybars and thought I would just pick up the endlinks as well... I've read I need the rear at the very least, but since I don't like installing things twice, I thought I would get the front as well and be done with it.
So which is better and why?
Also, is the rear adjustable aluminum plate really necessary? COBB says it is to keep the endlink vertical when adjusting to settings other than full soft.
I had a problem using the Kartboy end links with the front Cobb bar and ended up switching to the Cobb endlinks. Check out this thread on the topic: http://www.cobbforums.com/forums/showthread.php?t=31609
70s-gearhead is offline   Reply With Quote
Old 10-22-2006, 01:27 PM   #28
Muller Chevrolet
^dunno mine worked fine and so have others.
Old 10-25-2006, 12:12 PM   #29
IWSTI Addict since: Mar 2006
Originally Posted by SickSTi
kartboy..cheaper and better..
I went with Kartboy because they are cheaper, but I certainly think Cobb's are better. They use spherical bearings just like an OE part, only they're much stronger.
Kartboy's bushing endlinks work, but I can't imagine the bushings are happy during extreme compression or extension of the suspension. They're asked to flex quite a bit. Furthermore, they rely on lubrication to permit motion- there is no bearing.
Basically, the whole Cobb versus Kartboy thing comes down to a bushing versus a bearing. A bearing is better, but more expensive.
But they only need to resist stretching, and stamped steel should do that fine.
Old 10-25-2006, 12:26 PM   #30
Fav Mod: T2s and Recaros
IWSTI Addict since: Oct 2005
I'll reimburse you for the fender braces from TiC if you don't notice a difference.
