Old 06-18-2006, 04:14 AM   #1
Default which coilover is better? - and why stiffer isn't necessarily better
which coilover is better for 01 gdb?
1,Cusco zero 2r
2,Tein mono flex or flex
3,KW V3
Thanks!
wt421 is offline   Reply With Quote
Old 06-18-2006, 06:06 AM   #2
Trader Rating: (43)
Send a message via AIM to Z1 Performance
better for what? What do you use the car for?
no one is going to be able to comment on the Tein Mono, as they are too new
Z1 Performance is offline   Reply With Quote
Old 06-18-2006, 07:10 AM   #3
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
for anything you are doing, KW's hands down.
evilSTi7 is online now   Reply With Quote
Old 06-18-2006, 08:00 AM   #4
I don't want the noise(clunk),I use the car for street(70%) and I want long last.Is the inverted coilover always clunk,because my zeal xs always clunk,especially in hot temperture.
Old 06-18-2006, 10:21 AM   #5
Car: 05 sti...
Fav Mod: I Love my STi stickers!
Send a message via AIM to dlouie87 Send a message via MSN to dlouie87
i have flex....but i would get the cusco....but then people on here might say KW.....
dlouie87 is offline   Reply With Quote
Old 06-18-2006, 10:29 AM   #6
Generally I'd say KW, but you didn't specify what you wanted the coilover to be better at, so there really isn't a correct answer.
Old 06-18-2006, 10:56 AM   #7
Car: 05 Legacy
Most coilovers are going to make noise. Don't buy coilovers to do away with noises or think that they wont develope noise. If your car is for the street I would go KW. The intervals between rebuilds on the KW's are much longer than the cuscos or teins.
BayRain is offline   Reply With Quote
Old 06-18-2006, 11:37 AM   #8
Car: 01 GME(6) / 04 GDF(7
Fav Mod: Suspension bits
edit
thread merged.
Dylan is offline   Reply With Quote
Old 06-18-2006, 11:44 AM   #9
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
what are you using it for? Street, track, etc..
Old 06-18-2006, 11:47 AM   #10
You really have a 2001 New Age?
Old 06-18-2006, 11:55 AM   #11
Fav Mod: Protune thanks to Slowboy Racing
Send a message via AIM to BeattySTi
I have the Tein Flex w/ EDFC which enables me to be able to soften or stiffen the ride depending on what i am doing. Soft when the girl is in the car then switch to stiff for track use.
BeattySTi is offline   Reply With Quote
Old 06-18-2006, 04:38 PM   #12
520
Car: 03 EVO
Fav Mod: stock :(
how long does edfc take to install? sorry for OT ?
Old 06-18-2006, 06:54 PM   #13
Car: 05 white STi
Fav Mod: audio
it looks like a relatively simple install. the hardest part of the edfc install is going to be running the wires + mounting the controller.
OP: it seems that german c/o's provide a softer, more compliant ride and japanese c/o's are very stiff for the most part. that should be your main factor in picking a c/o. the reason you're ditching your zeals will not be fixed by buying one of these setups because those noises are present in most setups.
two things to check: preload on your springs, and to make sure everything is tight--from the strut tops on down to the base of the c/o's.
take a look at your lower control arms in the front to see if they are level or pointing up kinda like this \_/ (you get the idea, not quite that severe). they should be level or pointing down just a little, and your sway bar should not be so close to anything that it will knock against the control arms or subframe.
you can also get rubber pads to quiet the springs.
if you really want to ditch your suspension for something quieter, just get a spring/strut/strut top setup and do away with the coilovers completely.
jsmonet is offline   Reply With Quote
Old 06-19-2006, 01:54 AM   #14
I use two set of tein HA at my evo before, the noise(nacceptable. But the zeal clunk very loud after I used few months,just like the coilover was broken.ot clunk) was
Old 06-19-2006, 06:44 AM   #15
Trader Rating: (43)
Anything with a pillowball can develop noise over time - nothing you can really do about that.
I would agree the KW sound like the best option for you given your choices listed. Our customers have had rave reviews about them
