Old 01-25-2007, 05:51 AM   #61
Car: 05 Subaru WRX STi
Originally Posted by XDNBC
.... I have just bought a new STI Ltd and am interested in using it as a daily driver, for Solo 1 and 2, and non- competitive[?] track days. I am a biker and all these numbers are commonly measured and compared for various types of riding.
Good luck running the STI limited in Solo.... it has less than 1000 production number, so you have to run it in Street Modified class.
vampyr is offline   Reply With Quote
Old 01-25-2007, 09:32 AM   #62
Wheel33tist Whore
does this hold true even though it should fall on the same line as the normal STi?
there were only 500 or so of the sport Solstice sold (i think that's what they called it) and it was still in CS (won CS actually).
T3h_Clap is online now   Reply With Quote
Old 01-25-2007, 10:12 AM   #63
I don't mean to go off topic here... but wanted to point it out.
From what I was reading on my 2006 solo rulebook, if the production numbers for a model car are less than 1000, then it is not allowed in certain classes.
However, if the model is an option (such as buying the base corvette, and adding the z06 option), then it IS allowed.
The subaru STI Limited is a completely different model that was not considered an option to a base STI.
Old 01-25-2007, 10:16 AM   #64
Trader Rating: (43)
Send a message via AIM to Z1 Performance
I am pretty sure SCCA would not grant the limited a distinct model status - heck, I would bet half the people running a solo event would not even think or know it was anything other than a normal STi. Not to mention, its not like a Limited would have any distinct advantage over a previous gen model
Z1 Performance is offline   Reply With Quote
Old 01-25-2007, 11:10 AM   #65
Fav Mod: a garage
in AS if you get rid of the wing you are out of AS
Old 01-25-2007, 11:14 AM   #66
Car: 2007 STI LTD
As far as I know the STI Ltd is placed in A Stock like the other STIs. The only differences in the cars are cosmetic [that includes lack of wing at AutoX speeds]. In fact, the extra sun/moon roof, heated leather seats and added sound deadener make it a touch slower than the regular STI.
XDNBC is offline   Reply With Quote
Old 03-09-2007, 09:32 AM   #67
Fav Mod: Too Hard to Choose!
how about megan racing street series? I know megan racing is more of a
nissan fanbase, but i was wondering if anyone had any experience or has
heard anything about them for the sti platform
IStoSTI is offline   Reply With Quote
Old 03-27-2007, 08:31 AM   #68
Titanium Member
Fav Mod: Modified Stock Heat Shield
I plan on getting coilovers this year and also looking at megan. Here's Scooby South last Sunday using Megans in BSP to take the fastest Suby run of the day....
http://www.youtube.com/watch?v=QIG-2g9MzNQ
Looks like Megans work pretty good to me for the price...
Old 04-05-2007, 10:15 AM   #69
Car: Black 07 STi
Fav Mod: Coilovers
Originally Posted by jsmonet
it looks like a relatively simple install. the hardest part of the edfc install is going to be running the wires + mounting the controller.
OP: it seems that german c/o's provide a softer, more compliant ride and japanese c/o's are very stiff for the most part. that should be your main factor in picking a c/o. the reason you're ditching your zeals will not be fixed by buying one of these setups because those noises are present in most setups.
two things to check: preload on your springs, and to make sure everything is tight--from the strut tops on down to the base of the c/o's.
take a look at your lower control arms in the front to see if they are level or pointing up kinda like this \_/ (you get the idea, not quite that severe). they should be level or pointing down just a little, and your sway bar should not be so close to anything that it will knock against the control arms or subframe.
you can also get rubber pads to quiet the springs.
if you really want to ditch your suspension for something quieter, just get a spring/strut/strut top setup and do away with the coilovers completely.
what is a rubber pad ?
orvtech is offline   Reply With Quote
Old 04-19-2007, 06:06 PM   #70
Default Re: which coilover is better? - and why stiffer isn't necessarily better
i have an 04 STi and i have JIC coilovers and i was wondering if i could get some feedback on how good these are.
DecoySTi is offline   Reply With Quote
Old 04-19-2007, 06:07 PM   #71
GT R US
if you have the coilovers, why aren't you telling us how they are?
{{{just noticing this was your first post and the sarcasm could traumatize you for life}}}
i mean...congratulations on your first post. how about those jics. eh? (isert smiley face here)
Old 04-19-2007, 10:05 PM   #72
im just asking if they are a good company if theyre worth keeping and if theyre reliable. no need to be a prick, tuff guy.
Old 04-19-2007, 10:09 PM   #73
if you feel the need to talk crap on forums because its my first post. you should really think about going outside sometime and not having almost 4000 posts on some forums...i bet you have more posts on other sites too.
k so now that youre crying to mommy. can someone with a decent attitude help me out. thanks for all you non assholes
all im trying to do is find out if theyre reliable and worth keeping.
Old 04-20-2007, 03:54 AM   #74
Car: silver 05 STI
Fav Mod: Access port 2
I had HKS and now tein Expensive as hell , and they both sucked. Great for racing or autucross , but they make a ton of noise and the ride quality slowly degrades. It's softest becomes unbearable. A stock type with lowering springs is best. I switched to KYB's with swft springs. Much better and not killing my car.
paul n is offline   Reply With Quote
Old 04-20-2007, 04:17 AM   #75
Car: 06 STI...FP Green
Then you should have asked that instead of asking for feedback. Asking for feedback means you want to know how the handling, ride quality, etc is not if JIC is a good company.
Just an FYI learn to take some criticism without getting all but hurt over it, it will serve you much better here.
Chris is offline   Reply With Quote
