Old 10-25-2007, 06:56 AM   #46
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: free castor mod?
Originally Posted by CGMDan View Post
tr
It's starts getting to the point of asking how much caster is too much. Yes some cars are designed with greater amount of caster, but how much can you safetly add to the STi?
I've got the WL ALK and already notice the power steering having "issues" when turning the wheel at idle.
I've got RCE springs and get rubbing on the wheel well when turning the wheel say 50% and braking at the same time at slow speeds, or turning the wheel and going over bumps at slow speeds.
I don't think I would want to add more caster.
didn't see this until now. Tom Hoppe has played quite a bit with caster. 7* is the most you want to run, and even that's getting close to the edge. higher than that and the weight jacking starts to get screwy.
Turninconcepts.com is online now   Reply With Quote
Old 10-25-2007, 06:58 AM   #47
Trader Rating: (53)
Originally Posted by fullerton View Post
anyone with long-term updates on this?
any noticeable bushing wear?
Nope. Everything's still good. I recently checked this for a noise I was getting that was driving me batty. Took the front end apart 3 times in as many days. Turned out to be a ball joint had died without the traditional signs of death.
Old 10-25-2007, 07:00 AM   #48
abracious
Fav Mod: Track time
seems like an easy task to accomplish.
do you think i could simply back the two bolts out, rotate the "stud" and then re-bolt without any other disassembly?
Old 10-25-2007, 07:07 AM   #49
Trader Rating: (53)
That's what I did. I used a friend to help move things around to line it up though. I also used a bit of locktite on the threads, because I'm a dork like that.
Old 04-19-2008, 02:37 PM   #50
Car: silver 04 wrx sti
Fav Mod: tic coilovers
Clint,
No locktite where logical = dork
Locktite where logical = no dork
2 years ago I put 2 washers for each bolt between bushing stud and controlarm, with locktite, and got enough movement to move toe in 1/8".
I check these bolts ( and most suspension bolts) at every 3,000 mile oil change. Have had O issues.
I'll take a good look at the bushing studs when I install the TIC coilovers and Vorshlag camber plates I will be receiving soon ( I can hardly wait ).
If I can get similar movement from rotating bushing stud 180 degrees, I'll remove my washers.
Steve
slidewaysteve is offline   Reply With Quote
Old 04-19-2008, 02:42 PM   #51
Car: '04.5 STi
Fav Mod: ZZYZX
I'm running 6.8 degrees of castor. I wouldn't go higher, but this amount seems to work.
Old 04-19-2008, 06:42 PM   #52
Car: 05 crystal grey sti
what are you doing to get to that point?
kursplat is offline   Reply With Quote
Old 04-19-2008, 06:58 PM   #53
Car: '04.5 STi
Fav Mod: ZZYZX
Noltec race plates
They're nice, but they're thick and eat up a lot of travel space.
Old 04-22-2008, 09:19 AM   #54
Car: 2008 Pinarello FP5
THATS a good amount !!
that has to feel good.
WOW.
Myles
Old 04-22-2008, 02:23 PM   #55
Stretch,
I recall recently you mentioned a camber/castor tool from Sears you were going to try. How did it work, and what is the name and price of it?
Thanks,
Steve
Old 04-23-2008, 03:53 PM   #56
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
Clint (TurninConcepts); could you repost the original photo you attached on post #2? It doesn't appear anymore.
Old 04-23-2008, 05:57 PM   #57
Trader Rating: (53)
We don't have it.
Tony
Old 04-23-2008, 06:47 PM   #58
Car: '04.5 STi
Fav Mod: ZZYZX
WOW.
Myles
Oh yeah, the steering wheel has a very nice weight to it now. It also seems like steering feel and on center feel has greatly improved as well. Turn in response is sharp as a knife.
I can't make any specific comments as to exactly what effect it's had on performance based on observations behind the wheel, because the big caster number came with a lot of other suspension upgrades all at the same time. I could adjust it out and test it, but that's quite a bit of work.
I don't think I would go any higher than that though. The weight jacking effect is really obvious on a tight autocross course where sometimes the inside rear tire doesn't sit down fast enough. Usually smooth driving inputs are enough to deal with it though. On the street or track, the big caster number really seems to be completely vice free.
Old 04-24-2008, 02:43 PM   #59
We don't have it.
Tony
Would someone post a picture of the area that this modification applies to? I'd like to check it out but have no idea what to look for. Thanks!
Old 04-24-2008, 03:16 PM   #60
abracious
Fav Mod: Track time
the rear mount of the control arm.
if that doesn't make any sense to you, it may be prudent to have someone experienced help you with the mod, for safety's sake.
