Closed Thread
Old 04-16-2005, 11:30 AM   #1
www.Subie.tv is niiice
Default Suspension, Handling, & Stiffening Threads of Interest
Koni 05+ coilovers!
Aftermarket Spring rates listing
The Superior Aerodynamics of the 06 STI
SubaruOfGwinnett / Scott Siegel Performance Dissertation
Rambling Thoughts on Sways and Springs from TurnInConcepts
How the Whiteline Anti Lift Kit ("ALK") works, what it does, and the various options on the market
Cure the STi's handling woes
A must do for 2004 STis: Improve steering response and feedback by replacing steering bushings (2004s only)
STi Spring Installation with Photographs (revised 27-Apr-05 TRM)
Will installing strut bars help?
Cusco V-Brace DIY Install
The relative drop of various aftermarket spring kits for the STi
Bumpsteer, Camber Curves, and Caster effects on instaneous wheel camber
Determine if your JDM Pink Springs and GroupN Tops are genuine
Links to Whiteline 27-29mm FSB Issues w/Endlink Recommendations/Testimonials
General alignment discussion
Torque Specs for 04-07 struts
---- Off-site links -----
2004/2005 STI Aftermarket Springs: Rates and Drops
Alignment Thread
Anti Roll Bars v. Stiff Springs
FAQ: How to reduce understeer
Make your car handle like you like it
"Suspension Info" is a spring rate comparison chart
How do stabilizer bars (sway bars) work?
Even though its an RC site, this offers a relevant introduction to vehicle dynamics
How to setup a WRC for SCCA competition
Recommended Reading: High Performance Handling Handbook
More than enough Suspension HOW TOs and FAQs from Whiteline to keep you reading for days
Nivek is offline
Old 04-16-2005, 11:33 AM   #2
If you know of an important thread you would like referenced here, or information that should be included, PM the information to a moderator to be reviewed and posted. Thank you.
Nivek is offline
Closed Thread
