Old 03-13-2005, 05:16 AM   #1
Default RE: Richmond Va whats up?
I'm looking for the best alk.
I'm considering whiteline or perrin.
Does anyone know which one is better in terms of performance and build quality.
phillytec is offline   Reply With Quote
Old 03-14-2005, 12:40 AM   #2
Car: Cars, family, traveling
Fav Mod: USAF
Personally I would use Whiteline I have used their parts before and was and am happy with them I have two freinds who have used their ALK and are/were happy.
Silversatin is offline   Reply With Quote
Old 03-14-2005, 06:40 AM   #3
Trader Rating: (71)
Send a message via AIM to Paperchasin
Default RE: Best Price: Pink springs, new summah tires
they are all pretty much the same...i have the whiteline also...but the perrin positive kit would be good as well...
Paperchasin is offline   Reply With Quote
Old 03-14-2005, 08:19 AM   #4
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
does an alk really make a noticeable difference? or at least enough to justify spending close to $200?
Old 03-14-2005, 06:51 PM   #5
Fav Mod: Stealth mode
Default Re: RE: First track day experience in my MY05
Well I just received my Whiteline kit but have yet to install it, and I was surprised at how many other parts come with the main bushings. Can anybody confirm if the other kits include spacers and bolts to offset the U-brace like the Whiteline kit?
I am now considering waiting till I can afford the 14 pt GT-spec brace kit before installing the ALK, so I don't have to mess with the U-brace twice.
Snax is offline   Reply With Quote
Old 03-14-2005, 07:11 PM   #6
Trader Rating: (71)
Default RE: What mods wont void warenty?
there are spacers and wutnot that are needed to put the subframe back in place...due to the placement of the ALK, the subframe would hit it and thus, the need for those thick washers....
Old 03-14-2005, 07:36 PM   #7
Fav Mod: Sales@RaceCompEngineering
Send a message via AIM to rexorama
Default This is BAD !
Some people have had fitment issues with the Perrin kit. Supposedly Perrin is working on the issues. I have no personal experience with the Perrin kit but I thought I would pass this on, for what it's worth. I have heard no complants about the Whiteline kit.
rexorama is offline   Reply With Quote
Old 03-15-2005, 10:15 AM   #8
Default RE: What would my stock springs and struts be worth?
Thanks for the response. I currently have Hotchkis rear sway bar and Praxis suspension. I'm not sure if I need the alk, but I was looking for something to keep the front more planted during hard excelleration.
Old 03-15-2005, 05:58 PM   #9
Default RE: Since Nov. 04 But here they are
Nice synopsis nhluhr. Thanks!
I assumed the spacers were probably included for the reasons you mentioned. I thought it was worth noting that these kits include more than the pictures imply and are not a simple 2 part swap like I had assumed. It's no big deal to me really, it just means that what I had planned to do in 30 minutes or so could take a bit longer.
Old 03-19-2005, 04:48 AM   #10
TRM
uh, whut?
Fav Mod: wdb
Send a message via Yahoo to TRM
Default RE: Sorry, one more clutch question
seems funny to me that the ALK defeats anti-lift and anti-dive and then most people go to extra trouble with stiffer springs and more aggressive dampers to eliminate dive and lift.
i understand the theory...just seems strange.
TRM is offline   Reply With Quote
Old 06-03-2005, 03:29 PM   #11
Fav Mod: student
Send a message via AIM to scsi
great post!
scsi is offline   Reply With Quote
Old 06-03-2005, 03:36 PM   #12
jph
i recently asked around about the various anti lift kits, before ordering one. and this is the answer that made me go for the whiteline kit (haven't received my order yet, so i can't comment on how it feels)
All the parts out there that are similar to what the
Whiteline ALK's. However the Whiteline ALKs gives the most caster.
Old 08-11-2005, 11:37 AM   #13
Fav Mod: Dyslexia
Trader Rating: (13)
Originally Posted by nhluhr
Snax, I think you'll find the answer to this question in my comprehensive post above. Perrin, GTSpec, and Whiteline (KCA359) come with spacers/hardware.
Regarding installing the ALK with the subframe, I have recently ordered a GTSpec kit (I prefer the rubber bushing) and I will be attempting to install it WITHOUT the subframe spacers. I am pretty sure, after looking at the installed pic in the pdf I linked, that I can squeeze it in there with some "adaptive hammering" of the subframe to make room. I don't want to space the frame down because that means the 05STi underbody aero cladding will not clip onto the rear of the subframe properly.
The spacing of the subframe is done for two reasons:
-to allow room for the control arm to move down without hitting it (Bigger problem for the bulky boxed steel arms of the WRX)
-to allow space for the ALK to sit lower than the stock part
I am pretty sure with a mini sledge hammer, I can overcome both of these issues.
Thanks for the write up Nhluhr. I just installed today, not too bad, just time consuming. As you probably found out, the spacers were barely an issue. The only thing I could not put back was one of the plastic push in buttons in the back on each side & it really did not need it to be secure anyway.
I have not pushed the car hard enough to notice that much of a difference yet.
It does not seem that the alignment is out very much if at all by look & feel,
do you know what & how much it throws off the alignment?
Old 08-11-2005, 05:04 PM   #14
Fav Mod: Dyslexia
Trader Rating: (13)
I ordered the GTSpec ALK back in march and it has yet to arrive. At this point I doubt I'll ever get it so I asked the vendor for a refund.
The one thing I was really looking forward to trying is to see if I could hammer a 'dent' into the u-shaped subframe to make room around the ALK instead of using the handful of spacers. This way, everything still fits like stock.
Did it look like it would be feasible to do this?
-Nick
Suks bout the GT Specs. All the vendors out there, someones gotta have em.
I tried fitting it back in place with the white lines installed just to see how much I would have to bang it in, it could probably be done but not without compromising the integrity of the subframe.
Like I said b/f, the spacers were barely an issue at all fitting everything back anyway, i'm sure i could even get the last button in just drilling a new hole.
Old 05-22-2007, 11:28 PM   #15
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow Re: Which ALk is best?
How hard difficult is install on these?
scale of 1-10?
-Nigel
NewShockerGuy is offline   Reply With Quote
