Old 09-15-2004, 12:40 PM   #16
IWSTI Addict since: Jul 2003
Default Re: Anyone park their STi on the street?
so do the upgraded bunnies make noise when going over speedbumps? do the bunnies even fit over a speed bump?
LMFAO
matadorCE is offline   Reply With Quote
Old 09-15-2004, 01:11 PM   #17
IWSTI Addict since: Jul 2004
Send a message via AIM to drbiggly Send a message via Yahoo to drbiggly
Where is the grease fitting on the bunny exactly?
drbiggly is offline   Reply With Quote
Old 09-15-2004, 02:58 PM   #18
IWSTI Addict since: Aug 2004
Default FS: CARBON CONCEPTS CF ALTERNATOR COVER (Price Lowered!!!)
I would ask nick - after all it's HIS picture...
Mainstream is offline   Reply With Quote
Old 09-15-2004, 02:59 PM   #19
Car: silver 2004 STi
Fav Mod: Pinks or Hotchkis sways
IWSTI Addict since: Jan 2004
now we all KNOW you have greased the bunny before
surlysinglespeed is offline   Reply With Quote
Old 09-15-2004, 05:51 PM   #20
Originally Posted by nhluhr
hey Mainstream, if you wanna download and host the pic, just put an "a" on the end of the filename before the .gif.
it's all good - I saw your post and fixed it right away...
I just tossed that on here forgetting it was still linked to your site... sorry :wink:
no doubt that was a funny one though - nothing like a smoke and a pancake... and a bunny?
they are still $135 shipped... only 1 set left! ::bunny sold separately::
Old 09-20-2004, 03:06 PM   #21
IWSTI Addict since: Apr 2003
What the hell causes this end link to bend? Could it be jacking up the car at a bad angle? Dealers don't wanna warranty this!
Hispanics is offline   Reply With Quote
Old 09-21-2004, 06:52 AM   #22
Fav Mod: GT-35R
IWSTI Addict since: Jan 2003
it happens when the swaybar "flips" and the link is now bent over the lateral link down to the swaybar below it... this occurs when you jack the wheels off the ground. very annoying. I typically roll up on ramps in the rear and unbolt the endlinks before jacking it up. With my jack, i can get it just high enough that i can pull the ramps out from under the wheels.
does it happen no matter where you place the jack?
cnstman is offline   Reply With Quote
Old 09-21-2004, 07:04 AM   #23
nhluhr thanx for the heads up. They should have put that in the owners manual or something. SOA should be responsible for replacing these.
cnstman I'm guessing if you jack it from the center (where the rear differential is) you should be fine, since both sides of the suspension are being lifted at the same time.
Old 09-21-2004, 07:06 AM   #24
Fav Mod: GT-35R
good to know, thanks. i just got my hotchkis street set, and have to wait a bit for endlinks. will the stockers hold up for a couple of months? i only plan on using the middle setting on the rear bar. also, is flipping a problem with the hotchkis beefier mounts?
thanks!
Old 09-21-2004, 07:16 AM   #25
MHO wait and do everything at once. The stock ones should hold up fine if you don't jack it up wrong or take any steap driveways. But i would wait .
I've only heard of the stock ones flipping and bending the links.
Old 09-21-2004, 07:18 AM   #26
Car: 04 STi AW
Fav Mod: Logisitics Engineer
IWSTI Addict since: Sep 2004
I do not know that this problem is as common as some of you believe, I have had mine jacked up, one wheel at a time, and airborne, no flipping found.
Gogats is offline   Reply With Quote
Old 09-21-2004, 07:29 AM   #27
Fav Mod: GT-35R
have you taken some steep inclines at an angle where the rear inside wheel is off the ground then back on? just asking cause i take one of those at least 1-2 times a week.
thanks
Old 09-21-2004, 09:21 AM   #28
the street kit is built specifically to run with the stock equipment - the rear bar is not as stiff as the competition kit, which includes the endlinks...
you will be fine installing the kit without endlinks, but I would only recommend running the stiffest setting for autox or some other competitive driving...
I believe the main reason for the flipping bars is more due to the bar itself rather than the endlinks, even though they are weaker than they should be
Old 09-21-2004, 09:50 AM   #29
Car: 04 STi AW
yes there is a great hill that I jump downslope to slight incline to downslope
Old 09-21-2004, 10:59 AM   #30
Fav Mod: GT-35R
ok cool, you guys are great. i got my kit sooner than i thought i would. thumbs up for a good vendor!
