Old 07-16-2008, 05:30 AM   #1
Car: 04 silver STi
Fav Mod: More seat time
Default 04 .Wheel hub extreme heat
Ok, so this year I'm using R-comps for the first time Autocrossing. My concern centers on what I feel may be extreme heat being generated in my hub/front bearings.
After events when changing tires the front lug nuts are very warm, sometimes bordering on being too hot to handle depending on course layout ie; predominately left or right hand course. Sometimes the outside front wheel lugs get so hot they seem to expand at a different rate than the lug nuts. When this happens I can't get the nuts off of the studs without messing up the threads on the studs which then require replacement of the affected studs and lugs.
Does anyone else experience this phenomenon or is it particular to 04 cars because of their smaller hub/bearing assembly?
Should I just let the car sit until the lug nuts are cool to the touch before I swap tires? I could drive home on the R-comps and let the car cool off over night but that is not an ideal solution to my problem.
I don't have any outward signs of the hubs going bad yet other than knockback but maybe now is a good time to upgrade to the 6gun racing hub kit. I will stay with 04 bolt pattern because I have 3 sets of rims plus T2's for that fitment so the 05 upgrade is not an option.
The T2's are going to be installed soon so it would make sense to do the hub upgrade at the same time if thats the solution to my problem. Opinions to fix my issue are welcome.
Jeff
Sti loves to Ax is offline   Reply With Quote
Old 07-16-2008, 09:59 AM   #2
Car: 05 WRX STi
Fav Mod: RCE Tarmac-2's!
Default Re: 04 .Wheel hub extreme heat
I have an 05 STi with the larger hubs and I still notice a heat issue after long hard runs with the front wheels.
It has actually shrank 5 (had ordered a new set of 4) of my Rota center wheel caps to where they will not fit in the rim anymore. No, they are not worn or broke. It appears the heat actually shrunk them slightly to where they no longer fit snug.
It only happens to the center caps that are on the front wheels.
Long story short, if you are an 04 STi on the stock hubs and track/Auto-X the car you will most likely run into hub/bearing issues due to the heat.
JPotter is offline   Reply With Quote
Old 07-16-2008, 10:05 AM   #3
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
This is common on any car that is racing. The breaks generate a lot of heat and much of itis absorbed by the hub and wheel. It is always recommended to let the car cool ebfore doing anything to it. Especially removing lugs. A countless number of people have snapped lug studs when trying to remove lugs from hot studs.
Turninconcepts.com is online now   Reply With Quote
Old 07-17-2008, 12:19 AM   #4
Car: 04 silver STi
Thanks for the reply TIC. I"ll try letting my front hubs cool overnight before swapping rims. The rears don't generate the same amount of heat so I'll still swap those after the events. Hopefully this approach will yield better results for me.
