Old 07-08-2008, 08:46 PM   #16
Car: 06 white STI
Fav Mod: Borla catback
Default Re: 05+ owners; How long do your wheel bearings last?
06 STI, 24k miles, 15 or so aggressive track days, left drivers side bearing died but didnt realise until I was swapping my street wheels for the track. There was no indication of any wheel problem when driving to the track even though the wheel felt very loose when swapping it out. Repaired by local garage and SOA gave me check for parts and labor no questions asked.
cawayne is offline   Reply With Quote
Old 07-08-2008, 09:17 PM   #17
Car: 05 Subaru Sti
Fav Mod: Defi triple pod guages
So this item should be covered by warranty if less than 60k on car right.
STIFun is offline   Reply With Quote
Old 07-08-2008, 10:17 PM   #18
Car: 05 CGM STI w/goldies
Fav Mod: Advan A048's
yes sir!
crf-sti is offline   Reply With Quote
Old 07-08-2008, 11:24 PM   #19
Car: Black 06 STI
Fav Mod: Seatbelt fix, site avatar delete
How can you correctly identify a bad wheel bearing? I hear a howling noise that goes away on hills/crests and stuff. I am pretty sure its the bearing but I don't want to come to the dealer and get turned away for something stupid.
antonch is offline   Reply With Quote
Old 07-09-2008, 05:08 AM   #20
Car: 05 WRB STi
Fav Mod: PWT points.
Um regardless of whether it is a wheel bearing or not, if your car is making a funny noise you should have it checked. Never feel stupid about having something odd looked into - I do it whenever I think something has failed. I've been told several times before that everything looked okay, but that doesn't prevent me from being cautious about my sti investment
rmo55c is online now   Reply With Quote
Old 07-09-2008, 05:09 AM   #21
Car: 05 WRB STi
oh and to the original poster, im at 78K miles on my 05 now and have not a wheel bearing problem. I've had an excessively worn axle end and now I think I have a cv joint going in the front, but thats been about it on all those miles.
Old 07-09-2008, 06:37 AM   #22
Car: '05 CGM
Fav Mod: HPDEs
There are a couple of ways to identify a bad wheel bearing.
First is noise - left side wheel bearings will make more noise in right-hand turns because the left side of the car is "weighted". Similarly, right side wheel bearings will make more noise in left-hand turns.
It's possible that the wheel bearing will make noise when you're going straight ahead or turning in either direction, but generally you'll notice more noise when you're turning and the weight of the car is being shifted more onto one side of the car.
Second is looseness - jack up the corner of the car and get the tire/wheel into the air. Grasp the tire at the top and bottom and see if the tire/wheel wiggles as you push in on top, pull out on bottom, reverse and repeat. Any noticeable movement of the tire/wheel is an indication of a bad wheel bearing.
Hope this helps!
Gary
Old 07-09-2008, 06:44 AM   #23
STI Guru
Fav Mod: grip.
05 with 50k miles, fair amount of hard driving (back roads), one track day, one auto-x so far. no issues at all. car gets driven all year round as well.
Old 07-09-2008, 06:47 AM   #24
Car: 2005 STI
Fav Mod: Methanol
70k miles, 300+ auto-x on 17x9 +38 mm
05 sti, no probs yet
xrocket21 is offline   Reply With Quote
Old 07-09-2008, 06:50 AM   #25
NIИja
06, 50,000 hard miles, and 4 track days.
No problems.
Old 07-09-2008, 06:51 AM   #26
Car: 05 STi |STOCK|
Fav Mod: Not a post 07 sti fan
05, 60k miles Mixed track days, mountain runs and lots O highway driving. No issues as of yet and I drive the car like I stole it most of the time.
chargedvette02 is offline   Reply With Quote
Old 07-09-2008, 06:52 AM   #27
Car: 05 STi |STOCK|
No problems.
Wow, and I thought I drove a lot.
Old 07-09-2008, 09:27 AM   #28
I hear that using upgraded brake pads will create more heat which speeds up the failure of the bearings. I assume that most of you who track your cars have upgraded your pads? I am on Ferodo DS2500's.
na-STi is offline   Reply With Quote
Old 07-09-2008, 09:32 AM   #29
Car: '05 CGM
Fav Mod: HPDEs
I don't think upgraded brake pads alone will have that big an impact on the life of a wheel bearing.
For cars that are tracked, you have a number of factors coming into play:
1. Higher speeds before braking
2. Shorter stopping distances and shorter stopping times (e.g. harder use of the brakes)
3. Upgraded brake pads
4. R compound tires or their near equivalents
5. Plus size tires/wheels
Of that list of 5 factors, I'd say that upgraded brake pads probably have the least impact.
Gary
Old 07-09-2008, 09:40 AM   #30
Fav Mod: so far? RCE T2s
I replaced bearings about twice a year after I started autocrossing the car. I've driven over a year and many autocrosses on the 6-gun kit with no knockback. I also run big tires on the street and have put about 25k miles since I replaced the bearings. I bought the version that let me keep my three sets of 5x100 rims. I highly recommend the kit.
