Old 06-14-2008, 12:07 PM   #1
Car: 2007 SWP STi
Default RCE Black + Lowering plate? Bad idea?
How far off will this throw the geometry off?
If i were to go yellow's then it's a drop of 23mm and 20mm but the car will have less wheel gap in the back than it does in the front, so it'll look like a saggy butt.
So the other option was to get Blacks with RCE lowering plates. Which effectively make the drop 25mm and 10mm.
I'm sure maybe someone has experimented with both.
I almost prefer the look of the Black with lowering plate to the yellows with non-lowering plates.
Future/GDB/Driver is offline   Reply With Quote
Old 06-14-2008, 01:15 PM   #2
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
Default Re: RCE Black + Lowering plate? Bad idea?
I'm runing Blacks with lowering plates. I really like the combo from both an appearance and handling point of view.
Lowering the STI at all will start to change the geometry because the Roll Center drops 2.6 times faster than the center of gravity. But really, the drop in the roll center height isn't a huge deal in this situation unless you regularly drive at 9/10ths. You will notice a little more body roll, but a lot of it can be dialed out with the camber plates and a roll center kit like the Whiteline RCA.
Old 06-14-2008, 01:30 PM   #3
Car: 2007 SWP STi
Draco how is the lip holding up?
Old 06-14-2008, 05:19 PM   #4
Black Dragon STI
It looks really bad because I haven't properly screwed it in at the back. The paint's chipping, but otherwise it's holding up fine. It's a cheap Chinese knockoff of the Chargespeed V2 lip. I bought it specificly to take the brunt of any hits to protect my bumper. ANd it does that job perfectly.
Old 06-14-2008, 07:58 PM   #5
Fav Mod: Teh Mature Diffuser Will Return!
Send a message via AIM to KiR DieseL
Im going with cobbs and lowering plates.... Soon as i get the plates in the mail ill install em and see how it comes out. Should be interesting
KiR DieseL is offline   Reply With Quote
