Old 06-11-2008, 12:57 PM   #1
Car: 04 psm sti
Default coilover help
Hey everybody. My car is an 04 sti with about 35k on the clock. I've got a slight problem with my coilolvers and was wondering if you guys could help me out. I have been driving my car for about 3k on coilovers. Over that time I have occasionally heard this metal on metal noise coming from the front shock tower area. I checked everything under the hood and in that area as far as brakes and suspension and everything seemed tight. I looked at the spherical bearing where the top of the shock sits inside the camber plate and it had some dirt and light rust on it. I cleaned it out and put some grease in there to see if that solved the problem. The noise seemed to go away but than it came back. I checked the pre-load on the spring to see if maybe it was too loose but it was fine. I only hear the noise when i go over some slightly larger bumps and when i pull out of my driveway. I know camber plates will result in a lot more NVH than say stock or group N mounts but this just does not sound right and I only hear it on the one side. No leaking fluid or anything like that. My car is not slammed I have about 14.25 wheel center to fender rim in the front and about 13.5 in the rear. Any suggestions would be appreciated, Thanks in advance.
whifkey Sti is offline   Reply With Quote
