| | #31 |
| Junior STI Driver | I used to have the same bar settings as you 27/24, even 29/24 and felt 29 just pushed like a pig on corner exits.. and 27 pushed a bit too except for the feeling of a sharp turn in.. since then i've down sized the front bar to 22mm and things have become a bit looser.. Ran SOW in the hot months only to be slower by half a second.. so ill have to see if its faster once it gets cooler.. I dont know if i've down sized too much, speaking to alot of the race crews it seems they all suggest running a stiffer bar in the rear, so i thought i'd experiment but last time i went out it seemed to hold up well. just for reference.. I do have ball joint extenders, KW v3's, front rebound a little less then middle, rear rebound close to full stiff(robispec suggested). canted camber plates for more caster -2.5f/-1.3r This ad is not endorsed by this member. Please register or login to hide this ad. |
