Old 06-02-2008, 08:16 AM   #1
Default Stripped the nut on rear swaybar mount
I've been switching rear sway bars in and out to run track days and A/S in SCCA autocross. I stripped the 12 mm nut (stripped the pattern on the outside on the nut, not the bolt) on the left swaybar mount. Because I've swapped in and out so much, can I buy the whole mount (it looks like I can undo two bolts and get the whole mount to come out)? Anybody know what that mount is called?
The only other solution (in my mind) is to carefully drill the old nut off and get a new nut but these bars have been in and out so much it might be good to replace the whole thing. Track day coming up soon (outer track @ MMP!!).
Anyway, please give me ideas.
Thanks
wrxpappy is offline   Reply With Quote
Old 06-02-2008, 09:17 AM   #2
If in doubt, flat out
Trader Rating: (23)
Default Re: Stripped the nut on rear swaybar mount
rear stabilizer bar bracket (#4 in the illustration). They're inexpensive ($10 from subaru) and simple to replace.
Old 06-02-2008, 09:31 AM   #3
Thanks Snortky, it's the bracket that that bracket hooks to that I think I need. It's not the bracket around the bushing, I'd like to replace the bracket that the rear stab. bracket hooks to. Nice illustration by the way.
Old 06-02-2008, 11:14 AM   #4
Trader Rating: (23)
that would be number 4. number 3 is the strap that attaches the bushing to the bracket. I have mine off my car if you want me to take a pic.
Old 06-02-2008, 12:37 PM   #5
OK, I get it. Thanks for the help.
Old 06-03-2008, 07:43 AM   #6
Trader Rating: (23)
For reference, the part numbers for the rear stabilizer (sway) bar bracket(s) on 04-07 STIs:
20540FE200 (right)
20540FE210 (left)
