Old 08-03-2004, 06:59 AM   #1
IWSTI Addict since: Dec 2003
What is a fair price to pay for installation of Pinks and Strut Tops? Approximately how long should it take? Thanks.
crume is offline   Reply With Quote
Old 08-03-2004, 09:57 AM   #2
Car: 04 WRB/G STi
Fav Mod: Sz49 + Meth
IWSTI Addict since: Jun 2004
Default AFE air filter
Skilled mechanic with proper tools (air) can do it in under an hour but they'll proly charge you a minimum of 2-3 hours labor @ around $70 an hour.
Boostpimp is offline   Reply With Quote
Old 08-03-2004, 10:16 AM   #3
IWSTI Addict since: Mar 2004
I paid $120 at $60 an hour for a guy that took his time and torqued everything porperly while I watched. I don't want somebody putting my sh!t together with an air wrench.
droideka is offline   Reply With Quote
Old 08-03-2004, 11:56 AM   #4
Car: 05 Subaru WRX STI CG
IWSTI Addict since: Aug 2003
Spend $20 for the online service manual (thanks to 4ml1fn) and get some buddies and do it Its fairly easy (we've done my car a couple times and a wrx) and is not to bad if you find someone with air tools (they will definitely help). You'll not only save yourself about $200, but you'll feel good doing it as well and gain some knowledge good luck!
Robert~
Old 08-03-2004, 11:57 AM   #5
Car: 05 STI CGM
IWSTI Addict since: Nov 2002
I would think a couple hours. It is not very hard but as droideka said a skilled person is more efficient and knows their stuff much better that say someone like me. By the way calculate in the alligment expense/time after the install.
Cheers
Nick
titsataki is offline   Reply With Quote
Old 08-03-2004, 12:08 PM   #6
Car: '06 EB Evo IX / SSL
IWSTI Addict since: Feb 2004
Default THANKS!
i had read somewhere that you want to wait a week or so for the springs to settle before getting an alignment done..is this true? or not necessary?
Seranin is offline   Reply With Quote
Old 08-03-2004, 12:21 PM   #7
Car: 04 JBP STI "The Beas
Fav Mod: Sold the Beast, waitin for 09 Leg STI...Bye baby!!
IWSTI Addict since: Jul 2003
Send a message via AIM to salisburyv
Default EXACTLY!
I was quoted 275/installed and aligned...for the new tein s techs...I think that was fair so i'm gonna do it.
salisburyv is offline   Reply With Quote
Old 08-03-2004, 08:14 PM   #8
Static X, I was originally planning to do the install myself. That was until I had a bad experience installing the steering rack bushings. That mod appeared to be so simple but was a total pita. I guess now I'm gun shy. I also read that you need a spring compressor. Is that true or can you get them installed without one?
Old 08-03-2004, 08:44 PM   #9
Rev
STI Guru
Car: 06 V70R
Send a message via AIM to Rev
For the rears you won't need a compressor.
For the fronts, you will need it. Unless you have someone to help you out and push down on the spring while mounting the strut top.
Get the $39.99 ones from AutoZone, McPherson Spring Compressor.
Check out my sticky thread in the Handling/Braking forum, right at the top, for pics and tips.
Old 08-04-2004, 03:11 PM   #10
IWSTI Addict since: Aug 2004
i am a total newb to this, how do i know how much to "torque" it, cause i was reading the installs of the pinks and strut tops and it was posted how much to torque the screws and that just confused me.
imajinaxn is offline   Reply With Quote
Old 08-04-2004, 04:58 PM   #11
Rev
STI Guru
Car: 06 V70R
Torque wrench.
Old 08-04-2004, 07:07 PM   #12
Car: 04 WRB STi
Fav Mod: Trailer Hitch
Default New member with wheel question.
Imajin,
If you don't know what a torque wrench, this is not the job for you. You'll hurt yourself and possibly screw up your car. If you want to learn, suggest you find someone who will let you watch.
You need to to decide if you're a work on it or get it done by someone else kindof guy. Doing it yourself requires a fairly decent investment in tools and time. Also, I'm not sure I'd want to learn on my new $30,000 car.
Don
donmei is offline   Reply With Quote
Old 08-04-2004, 08:28 PM   #13
IWSTI Addict since: Apr 2004
Are you saying that this can be safely done without a compressor?
The front & rear can be dismantled & reassembled (shorter but with slightly higher rates) simply by using body weight (while some one else threads the nut)?
2cati is offline   Reply With Quote
Old 08-04-2004, 09:03 PM   #14
Originally Posted by donmei
Imajin,
Don
well i own a 2.5 rs and a wrx, i have worked on both a little, but these are amatuer (SP?) like installing strut bars and what not. when i hear you guys talk about how much torque to apply, i just tighten so i know it won't shake. should i just go and ask somebody how to torque something with the correct measurements?
Old 08-04-2004, 10:35 PM   #15
Car: 04 WRB STi
Sure, torqueing something up is easy. My point was that your question showed that you had not done any real mechanical work. Replacing springs can be easy, or it can be difficult. It depends on the car, the amount of corrosion, etc. Have you ever used a spring compressor before??
I'd just hate to see you screw up your car if you've never done this kind of thing before. Do you know anyone locally who is doing it? Then you can help and learn in the process.
Thats how most of us who are a little more accomplished learned. One big difference though. When I learned to turn wrenches, it wasn't on my brand new $30,000 car. I screwed up. I learned. I broke stuff. I cost myself money. It was fun and sometimes stressful. Sometimes infuriating. But it was all good. I wouldn't have the ba11s to learn on my STI. Thats mainly it.
Also, now that I'm older, I've started paying people to do the boring dirty jobs. I have a mechanic who I trust 100%. Thats part of my equation. If I didn't have him, I'd do more myself.
Hope this helps.
Don
