Old 05-22-2008, 02:01 PM   #1
Car: suebahroo
Fav Mod: KB SSS
Default coilovers with rear camber bolt?
just wondering if the whiteline camber bolts part number KCA414 are good enough to straighten out my rear wheels. theres too much negative camber in the rear. also, do they replace the top or bottom stock bolt? Thanks fellas.
dangk is offline   Reply With Quote
Old 05-23-2008, 04:45 AM   #2
Reasonable
Fav Mod: correct grammar
Default Re: coilovers with rear camber bolt?
You can use those (IIRC) or Ingalls. I have a set of Ingalls in the rear of my car doing exactly what you're wanting, and also giving me tire/strut clearance.
Old 05-23-2008, 05:21 AM   #3
Car: 05 WRB STi
Fav Mod: PWT Points
Those are the ones I use on the rear as well. Use the installation instructions for the best advice on settings. Here you go:
http://www.globalperformanceparts.co...KCA4(SIZE).pdf
I ended up using the top holes because the coilovers caused close to -1.5 camber already in the rears which is where I wanted. I just wanted fine adjustment, so I stayed in the top hole.
Old 05-23-2008, 04:18 PM   #4
Car: suebahroo
Fav Mod: KB SSS
cool..thanks guys..
