Old 05-23-2008, 07:53 AM   #16
Car: 2004.5 Subaru WRX ST
Fav Mod: 17x10s
Default Re: KW V3 extended adjusters
My rear seat is only secured via the middle clip, and I can pull the left and right side cushions away and reach back to acquire access to the adjusters. An extended solution would be appreciated, as well as an easier way to access the front lower adjustment.
loworbitSI is offline   Reply With Quote
Old 05-23-2008, 08:24 AM   #17
Titanium Member
Fav Mod: Bill
Ditto....I leave a hex key in the top of each rear T2 and the seat clipped only in the middle....
Old 05-23-2008, 09:58 AM   #18
Fav Mod: 11.5:1 Q-Rack
Originally Posted by Drag-On View Post
Wow, that is a nice design. How is your adjusting holding up? Have you had problems with the hex key moving when the car is in motion?
They have never slipped out. The metal does conduct a little more sound from the coilovers. The additional noise is worth it for the ease of adjustment as far as I am concerned. Other than that, there is no downside.
LeiboWRX is offline   Reply With Quote
Old 06-15-2008, 02:48 PM   #19
Car: 07 CGM STi
Fav Mod: For those 13 seconds or less, I'm free!
Send a message via AIM to Acejam2k
Bump for this! I could of really used some of these this weekend for my T2's
Acejam2k is online now   Reply With Quote
Old 06-15-2008, 07:23 PM   #20
Car: UGM 07 WRX STI
Fav Mod: RCE T2s
Subscribed! Would love to actually hook in the corners of my seat so the car doesn't look broken through the rear window....
pinkertonpunk is offline   Reply With Quote
Old 07-25-2008, 05:57 AM   #21
Car: UGM 07 WRX STI
Fav Mod: RCE T2s
Any update on these RCE? Getting sick of fishing around for the rear top adjuster hole at events....
Thanks!
Old 07-25-2008, 07:21 AM   #22
Car: 2008 Pinarello FP5
While KW has been slow to respond, I found a kit of 10 T handle allen keys that includes a 2mm version. The handle is the perfect length for the rear seat. I contacted the company and await a quote for JUST the single 2mm units. This would allow for the handle to reach thru X braces and the seat in a nice neat manner.
I do need some help though. Can someone tell me the exact length needed to sit in a perfect position above the seat but not sticking out?
Myles
(alone today because all employees are on vacation at the beach)
RaceComp Engineering is online now   Reply With Quote
Old 07-25-2008, 07:39 AM   #23
Fav Mod: T2s and Recaros
Myles
You get that set I showed you? I'd want another inch or two on that for better clearance.
Old 07-25-2008, 07:49 AM   #24
Thats what I thought, so I am asking for it to be longer. (ewww,..that didnt sound right)..
Mw
Old 07-25-2008, 08:53 AM   #25
Mw
Let me know what they say and I'll buy one off ya (the allen key, not whatever you want longer.) jk
Old 07-25-2008, 10:11 AM   #26
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Myles - 2mm hex stock into a short alum bar that's been bored for it and a set screw to make the t-handle.
Old 07-25-2008, 12:07 PM   #27
yeah I was thinking that too, but have been so busy with other things I wanted a turn key thing. Let me see what I can come up with.
Mw
Old 08-18-2008, 05:34 AM   #28
This is what I have been using -- no issues yet:
EKLIND 54920 T-HANDLE HEX KEY 2MM 9'' ARM CUSHION
This might work: Allen 2mm Cushion Grip T-Handle Hex Key, 6 inch length - Model 57841 at Sears.com
Soulive is offline   Reply With Quote
Old 08-18-2008, 05:49 AM   #29
Car: UGM 07 WRX STI
Fav Mod: RCE T2s
Originally Posted by Soulive View Post
So that first one sticks up over the seat back and you can fully clip the seat in place? I have been using that 6" one to adjust them from ACE but it sure isn't long enough to stick up over the seat back. It is frustrating just sticking it down in there and blindly fishing around for the adjustment hole.
Old 08-20-2008, 09:26 AM   #30
Yes, they stick out with enough clearance to easily adjust with the t-handle. Most people who take to browsing the back seat area from outside the car don't even notice them. The only time they have fallen out is when I've strong armed the seat cushion. They could even be cut down a bit for a more flush look.
