Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > Exterior/Styling
Old 05-15-2008, 09:16 PM   #1
Fav Mod: Starving my STI
Trader Rating: (12)
Default Carbon Fiber Doors
Is Seibon my only option? Anyone done them? I'd like to see some pics.
Should I do the doors and Spec C glass at the same time to save on labor?
I'm wondering if I should buy an extra set of "door guts" so that I can bolt and unbolt the stock and CF doors as an assembly as needed.
I'm also thinking of doing that CF roof with a bud of mine. We want to order 2 to save on shipping and labour possibly. I figure the roof and glass all should be done at once (at least the front and rear glass)... door glass can be done later.
Old 05-15-2008, 09:24 PM   #2
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
Default Re: Carbon Fiber Doors
i know phil @ element runs cf doors on his time attack car (not sure what model) but he might be a good person to talk to.
Old 05-15-2008, 09:25 PM   #3
Car: '05 CGM STi
Why do glass? Why not plexi? Wouldn't it be lighter?
Old 05-15-2008, 09:41 PM   #4
Car: Blue w/ a crapload o
Fav Mod: anything I can do myself
Send a message via AIM to ucsti
How much weight is that all going to save you?
ucsti is offline   Reply With Quote
Old 05-15-2008, 09:44 PM   #5
Trader Rating: (12)
Cuz plexi sucks. I've run it before. that is for a pure race car only. It scratches easy and doesn't let light through at the proper angles... it distorts images.
My car is a daily driver.
Old 05-15-2008, 09:44 PM   #6
Trader Rating: (12)
I heard 22 lbs on the glass, 13 lbs on the roof, about 80 lbs on the doors.
Old 05-23-2008, 01:57 AM   #7
Fav Mod: Crawford
Send a message via AIM to 07 Flt4bxr
sounds interesting. i wouldnt mind haveing my car lose some weight
07 Flt4bxr is offline   Reply With Quote
Old 05-23-2008, 03:30 AM   #8
But is most of that weight the safety structure in the doors? That's what I'd be most curious to know, because the safety structure isn't something I'd remove and it looks quite heavy. The inside liner of the door is plastic and light already, so the only weight savings I can think of are from the exterior sheet metal. (Don't I remember reading you already switched to manual windows?)
Old 05-23-2008, 06:28 AM   #9
Car: WRB 06' STi
Someone correct me if I'm wrong. This is all just from upon examination from stripping my two damaged doors after my car got hit.
The front doors only have two real "fixed" (as in welded to the inside of the door) structural safety supports in them, the rear door only has one. The rest of the safety structure comes from two braces that also work with the window mechanism. The rest of the strength comes from the way the metal is folded and shaped to make it stronger. I'd think the seibon doors resemble the same internal structural supports as a OEM door.
The first thing I thought of when I lifted my rear door with all the internals and glass was wow, someone can easily save a lot of weight with lighter doors. The savings would be huge, as Anorexic said already.
Had my internal guts not been damaged, I could have sold you passenger front and rear everything for super cheap, but the majority of it had some bad deformation
m3_arch is offline   Reply With Quote
Old 05-23-2008, 08:56 AM   #10
Car: 05 WRX STi
I have all of the 4 doors window motor slider and anything else you need from inside of the door.
I have weld in a 8 point roll cage and my factory doors are all plasma cut to save weight. I will post picture of my cut doors for you to see.
If you need anything from inside or all the switches from all the doors, please let me know. I can sell it for good price.
Old 05-23-2008, 09:13 AM   #11
Car: 06 Subaru imprezaSTi
Fav Mod: Prodrive
your not worried about crash safety with carbon fiber doors? i like the weight loss and the look but for a daily driver it's a little much. Here's a pic i have from the Seibon doors i took at the SEMA show
steelgraySTi06 is offline   Reply With Quote
Old 05-23-2008, 09:15 AM   #12
Fav Mod: Prodrive
If your trying to get a group buy for a carbon fiber roof count me in
Old 05-23-2008, 09:23 AM   #13
Muller Chevrolet
Fav Mod: fp green
i think seibon and maybe l'aunsport make some..but i'm not certain about l'aunsport, i have just seen them on their CF sti.
i plan to drop some seibon doors on my car in the long run.
Old 05-23-2008, 12:43 PM   #14
Car: PSM 05 WRX STi
Fav Mod: Coming Soon : Access Port, Cobb TBE, and everything like the rest.
Personal opinion: the stock doors are light enough!!! compared with other cars
dreamvang is offline   Reply With Quote
Old 05-23-2008, 07:24 PM   #15
Car: 04.5 STi- PSM
Fav Mod: learning how to drive
it can always be lighter my friend
misterwaterfallin is offline   Reply With Quote
