Old 07-30-2004, 03:53 AM   #1
IWSTI Addict since: Apr 2004
Default start small
Guys - I've noticed the subtle clunk (or click) that is notced when pulling away from a stop or when accellerating hard (2 gear rolling - without shifting ie staying in the same gear).
It's not the same as the obvious "clunk" you feel when accellarating hard and shifing the 1-2 shift.
The car is completely OEM however the dealer replaced the transmission a few months ago - I wonder if something was not tightened or worked it's way loose.
I was planning to do the whiteline diff kit - see if that addresses it..
2cati is offline   Reply With Quote
Old 08-04-2004, 01:28 AM   #2
IWSTI Addict since: Jun 2003
Have the dealer replace the LR and RR axle nuts or do it yourself ($7 each). It should solve your issue.
majmun is offline   Reply With Quote
Old 08-04-2004, 08:12 AM   #3
Car: 2004 STi
Fav Mod: FP Green
IWSTI Addict since: Feb 2004
Send a message via AIM to MauroMotorsports
Upgrade your mounts to Group N...clunking gone
MauroMotorsports is offline   Reply With Quote
