Old 05-18-2008, 07:26 PM   #46
Car: PSM '04 STi
Fav Mod: 6pt harness
Default Re: The Ultimate Street Suspension.
Subscribed!
nero9 is offline   Reply With Quote
Old 05-18-2008, 07:32 PM   #47
Car: OBP 07 STI
Draco....I am runnng the Ohlins FP, Max-C Plates, Group N Rear TH, ALK, Roll centre adjust kit, WL 24mm adj F&R....now you have me thinking of by-passing the brake rotor upgrade...just going with pads and converting the rest of my suspension.....lol
Love the Ohlins and wow what a difference the ALK made.....
Thanks for the tutorials.
2007cdnsti is offline   Reply With Quote
Old 05-18-2008, 07:38 PM   #48
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
You'll really like the Bushings. And they aren't that expensive, you can still get that rotor upgrade. Though as far as brakes go, the stock rotors are really good. I'd want slotted rotors, but only because of the increased water clearing. Otherwise, the stock blanks are fine.
Old 05-18-2008, 08:45 PM   #49
Car: OBP 07 STI
I was cnsidering the DBA 4000 slotted with Ferado 2500's......stock pads are shot but the rotors are still fine....so maybe on to the suspension...;-)
Cheers
Old 05-19-2008, 04:30 AM   #50
Black Dragon STI
Cheers
Well, I guess if you can corner faster, you can brake less.
Old 05-20-2008, 05:44 PM   #51
Car: Black 06 STI
Fav Mod: Seatbelt fix, site avatar delete
It has been 2 days since the last update....any more updates :-D
antonch is offline   Reply With Quote
Old 05-20-2008, 05:46 PM   #52
Car: RBP 05 2.5RS Wagon
Fav Mod: Group N Lateral Link Bushings
I'll be interested to see what he has to say after this Saturday. That'll be a REAL test of the car.
williaty is offline   Reply With Quote
Old 05-21-2008, 03:32 PM   #53
Black Dragon STI
Working on the ALK/RCA section now.
EDIT: Done!
Old 05-21-2008, 05:30 PM   #54
Car: 07 STI LTD SWP
Fav Mod: Tuning by Jorge!
I'm very interested in how you like the Ohlins suspension; I'm thinking about doing that myself.
Capn How is offline   Reply With Quote
Old 05-21-2008, 06:18 PM   #55
Black Dragon STI
Love it!
Old 05-21-2008, 06:39 PM   #56
I've ridden in his car a couple of times since then. The Ohlins dampers are a HUGE improvement over stock. They're also definitely better than my current dampers, Tokico D-Specs. However, I don't think they're 4x as good yet they cost 4x as much. I would say the Ohlins are a little more than twice as good as the D-Specs, but since when in motorsports was price ever linear to performance?
Mostly, I'm interested to see what he has to say in the section he's writing now.
Old 05-22-2008, 08:53 AM   #57
Black Dragon STI
The ALK/RCA section is done as far as I can for now. Next up is the Strut/Spring/Plate section.
Old 05-22-2008, 08:59 AM   #58
Originally Posted by Draco-REX View Post
With the ALK installed there is no more Anti-Dive geometry, and the Anti-Lift geometry has been changed to "Pro-Lift" geometry.
While this is definitely arguing semantics, I don't think it's correct to say that the suspension geometry has been changed to "pro-lift". Whiteline has said that the ALK simply removes all the anti- properties of the front end, leaving it neutral.
Old 05-22-2008, 09:02 AM   #59
when you lower an STI your RC lowers 2.6 TIMES the amount you dropped the car. You've lowered the CG of the car, great. But you've just lengthened the "lever" that makes your car roll by nearly three times as much.
Again, nit-picking here. As you first lower the car from stock, the rate of Roll Center vs Cg movement is smaller than that. As increase the lowering, the Roll Center starts moving faster and faster compared to the Cg. It'll end up dropping more than 3x as fast as the Cg.
Old 05-22-2008, 04:42 PM   #60
Black Dragon STI
According to Whiteline's paper on the ALK, the ANti-Dive goes from 22% Anti-Dive to 0%, however the Anti-Lift goes from 6.5% to -6.1% which they state is "Pro-Lift".
True, but 2.5+ times is a good rule of thumb.
