Old 05-12-2008, 10:34 PM   #1
Car: 07 WRB STI, 90 BNR32
Fav Mod: K40 Radar Jammer
Default X-Brace & Rear Camber Plate?
This may be a newb question....I just installed an X-brace today on my 07 Sti and was wondering if it is possible to run Vorshlag camber plates in the rear with the x-brace installed?? I am in the process of ordering coilovers and was going to order Vorshlag camber plates front and rear. If I cannot run rear camber plates, what are my other options? Camber bolts? Ball joints?
KUEDA is offline   Reply With Quote
Old 05-12-2008, 10:40 PM   #2
Default Re: X-Brace & Rear Camber Plate?
shouldn't be a problem at all x braces and strut tower braces just bolt onto the studs it doesn't effect chamber plates correct me someone if I'm wrong.
efinirx8 is offline   Reply With Quote
Old 05-13-2008, 04:46 AM   #3
is, in fact, a lolcat.
Fav Mod: banhammer
I'm running Vorshlags with an X-Brace. Your only trouble is going to be plate adjustment, as it is difficult if not impossible with the X-Brace installed. I have my rear camber set at -1.5 degrees and that's where I intend to leave it. I also have camber bolts in the rear (used for inner strut clearance, long story ).
I actually have TiC SSTs installed as well, and the adjuster knob is installed. I can adjust it with the X-Brace installed.
Old 05-13-2008, 08:23 AM   #4
Fav Mod: me
I too have an X-Brace, which is sexy. Adjustable lateral links would not only simplify camber adjustments, but also eliminate some ribber bushing compression. I really liked the improvement. During steady state cornering, the car would push and then pull in during throttle application and lift from the stock bushings. I thought it was due to the tire tread crawling. It's more rock solid now and improves my confidence in my driving. It does add interior noise though.
Treadwell is offline   Reply With Quote
