Old 05-11-2008, 07:06 PM   #31
Car: White 06 WRX STI
Send a message via AIM to Sleepy514
Default Re: White 06 STI dumped on Megan racing coilovers
Originally Posted by Future/GDB/Driver View Post
it's probably just a lot of camber. If you want it to handle better, you do need to raise it up.
Yes it has very Neg camber at the moment but tomorrow i'm gonna aling her right up and THEN ill see my rubbing issues because positive cam in the rear will push the tires towards the fenders.
Sleepy514 is offline   Reply With Quote
Old 05-11-2008, 07:08 PM   #32
Fav Mod: T2s and Recaros
Originally Posted by Mykl View Post
Ok, so if he's got 4.8 inches of travel before he hits the bumpstop, and he's got 2 inches (MAX) of travel before his tire hits the fender....
These things have an 8k spring up front, right? How long are the springs and how far can you compress them until they bind?
I have the same rates on my car, and it's set to have a max of 2 inches of bump travel because if it travels any more on my 7" springs they'll bind. I have hit bumps that have caused them to bottom out. If the same thing happens to this car, it's possible that the tire could go so far that it would damage bodywork.
yup, good question, thats something i wish i knew.
Old 05-11-2008, 07:09 PM   #33
Car: white 04 wrx STi
Fav Mod: New head lights
I don't know much about suspension so I couldn't tell you ho they are set. Cyrus at Megan racing said that he set the pre-load to their stock specs. Some times over bigger bumps it makes a clanking noise.
bigfathuero_sti is offline   Reply With Quote
Old 05-11-2008, 07:16 PM   #34
It depends on the length and stiffness. If they're short and stiff you'll definitely know when you hit them. If they're long and progressive like the OEM Subaru bumpstops it's really hard to tell.
Old 05-11-2008, 07:22 PM   #35
Car: '04.5 STi
Fav Mod: ZZYZX
I guess it's entirely possible that the noise could be coming from the springs if they run out of travel and bind? The way to find out if they're binding is to check the springs at the middle. If some of the paint has been removed between the coils, they've certainly bound up at some point.
Also, if these coilovers don't have bumpstops, which they probably do, the noise could come from the strut coming into contact with the camber plate.
Old 05-11-2008, 07:28 PM   #36
Also, if these coil-overs don't have bump stops, which they probably do, the noise could come from the strut coming into contact with the camber plate.
Thanks I will check that out. But other than that noise they feel smooth. I don't see why they are telling him that h needs to raise it to handle better, I thought the lower the center of gravity the better?
Old 05-11-2008, 07:38 PM   #37
Car: '04.5 STi
Fav Mod: ZZYZX
Lowering a strut car too far kinda screws with the suspension geometry to the point that it is possible to go too far. People have written books on the subject and there's plenty of info around here about it. Search for 'roll center' and 'camber curve.'
Old 05-11-2008, 07:43 PM   #38
Damm this makes me think "Is mine to low" I will do some more reseach maybe, It is. But then thats why I bought this type of coil-overs, so I can play and adjust. Thanks for the info
Old 05-11-2008, 10:34 PM   #39
Send a message via AIM to jermdeez
dude how many miles on on your car? how is your rear bumper so shiny and clean.
jermdeez is offline   Reply With Quote
Old 05-12-2008, 09:52 AM   #40
Photography Mod
Originally Posted by SRT4_2_STI View Post
From a handling standpoint, no, but from an aethetic standpoint... that depends on who you are.
Personally, I love slammed cars, but I don't like the reverse rake on this one. However, I have a feeling that I'm not going to get a whole lot of support on this site.
Front should either be a half inch lower, or back a half inch higher.
for looks, some cars do look good lowered. I think STI's do look good with about none to 1/2 inch wheel gaps but I daily drive my car and looks aren't as important as performance and ride quality.
most people around here aren't into slammed and are very educated on the suspension/geometry of our cars. you won't get a lot of support for "how to slam my car"
Old 05-12-2008, 10:06 AM   #41
Car: 06 STI
Looks fantastic!
Too low for me, especially with the roads out here, though. :-/
STIfrog is offline   Reply With Quote
Old 05-13-2008, 02:22 PM   #42
Car: aspen 2005 wingless
Originally Posted by Sleepy514 View Post
I could have a cadillac ride if i wanted to turn the dampers to 32 making them very soft.
I used to have those coilovers. They will never ride smoothly. If you think so, you've never driven on a good suspension. I will never recommend those coilovers to anyone I know, even if that person is my worst enemy, has back problems, and travels over a pothole-ridden 30 mile commute each day.
Old 05-13-2008, 02:26 PM   #43
Car: OBP 06 WRX STI
Fav Mod: cobb ap
hey as long as you like it who cares. if you're into handling, maybe a little too low. but dumped cars do look sweet. personally, i like it! looks great!
BMX_STI is offline   Reply With Quote
Old 05-19-2008, 05:55 PM   #44
Car: 07 SWP STI
Fav Mod: Strength Shoes
the last pic is nice!
STI23 is offline   Reply With Quote
Old 05-21-2008, 10:01 AM   #45
Car: 06 sti
so what brand r u compairing these coilover to that make them so bad? just curious not favoring either side, thanks
edit- to op, car looks good but a little higher will still look badass and u will have no prob tearin up ppl tryin 2 keep up on the twisties, best of both worlds....
bhp808 is offline   Reply With Quote
