Old 04-25-2008, 08:03 AM   #1
Car: Autox solo2
Fav Mod: More high-test gas.
Default Durability of aftermarket struts/shocks ? -Ohlin FPS
My experience with Bilstein heavy duty shocks and Bilstein sport strut-shock
kits is they last 200,000 miles and the first 100,000 miles' performance will be
much better than stock/OEM.
Reading here about coil-overs, I see rebuilds at less than 50,000 miles, and
even swapping out for winter.
My 2005 STi with 44,000 miles has worn/leaking rear shock tubes (causing the
infamous low speed clunking). Would replacement shocks/inserts, or whole
struts like the Ohlin fixed perch struts last longer than stock/OEM in a daily
driver ?
If the vendor picture shows two front struts, does the price and package
include rear struts as well ?
http://www.racecompengineering.com/c....asp?itemId=62
squid is offline   Reply With Quote
Old 04-25-2008, 08:10 AM   #2
Fav Mod: T2s and Recaros
Default Re: Durability of aftermarket struts/shocks ? -Ohlin FPS
I would wager good money that the Ohlins FPS would meet the long term mileage needs you've come to expect from the Bilstein product. The price and package from RCE includes all 4 struts that you'll need.
Old 04-25-2008, 08:11 AM   #3
STI Guru
Fav Mod: grip.
i honestly dont think many people around here have had their car for 200,000 miles let alone with aftermarket suspension...so that is kind of moot at this point in time.
and it includes all 4, i bought mine from RCE.
Old 04-26-2008, 07:07 AM   #4
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
I believe that Ohlins has stated that the FPS don't require rebuilds. That would seem to me that they are designed for a long life.
Old 04-26-2008, 08:02 AM   #5
Trader Rating: (50)
That pic shows 1 front and 1 rear. The pricing is for all 4 units (2 front and 2 rear).
Longevity really depends quite a bit on how you drive the car, and what springs are on it.
I guarantee that the dampers will last longer for someone who just daily drives the car vs. someone who races every weekend.
I can also guarantee that the damper will last longer on a setup that doesn't slam the car (ala stock or mild drop springs) vs. a setup where someone slams the car (ala Tein S-tech springs).
In the end the aswer is it depends. I know that's not a good one, but there are too many variables at play. Given all other things being equal, and all that you have replaced are dampers then the higher quality aftermarket setups will live longer.
Old 04-26-2008, 08:08 AM   #6
All very true, but if he's gotten 200k out of Bilsteins before, this particular user should get the same from the Ohlins, IMO.
Old 04-26-2008, 09:37 AM   #7
Car: 07 STI UGM
Fav Mod: Boob jobs
Why don't you just get Bilsteins then? The prodrive kit uses Bilseins and I believe it is available again.
Lurker is offline   Reply With Quote
Old 04-26-2008, 05:53 PM   #8
Car: 06 Subaru WRX STI
is it? thru which vendor?
RyanLee is offline   Reply With Quote
Old 04-27-2008, 03:51 AM   #9
Car: 05 STi - Black
Fav Mod: No Lien
Cosworth....
2700 bucks
05_GD7 is online now   Reply With Quote
Old 04-28-2008, 11:55 AM   #10
Originally Posted by 05_GD7 View Post
Cosworth....
2700 bucks
I should just get Ohlin +RCE yellow...
