Old 04-23-2008, 08:11 PM   #1
Car: 05 Subaru Sti
Fav Mod: Twin Turbo
Default Need help with setup
Ok I have Whiteline 24mm adj up front, 22mm adj back, HD mounts, Kartboy endlinks, Group N tophats all around and Prodrive Springs. Tires are 225/45/17 RE050A Pole Positions
I Auto X once a month, do I need a ALK with this setup?
What kind of a alignment should i get after everything is installed?
Front Rear
Toe= Toe=
Camber= Camber=
Caster= Caster=
I know you cant change some on the rear but I put it all in there anyways.
Any and all help would be great.
BigRigger is offline   Reply With Quote
Old 04-23-2008, 09:55 PM   #2
Car: 07 STI UGM
Fav Mod: BOLT ON BOOBIES
Default Re: Need help with setup
I'm no expert, but the ALK will bump you into a class that you may not be very competitive in. If that bothers you don't get it. You could try the free caster mod and nobody would know, except you and that depends on your character. I can say, after taking my ALK off (for the reason above) I do miss the sharper turn in and full throttle corner exit.
Alignment: Max your front camber (even each side). Get some camber plates if you got cash or camber bolts if you need time to save up for the plates. Set your toe to 0 all around. Not much you can do in the rear.
ConradSTI is online now   Reply With Quote
Old 04-24-2008, 12:11 PM   #3
Car: 2008 Pinarello FP5
what he said...........
Mw
