| Gold Member
Car: 07 OBP STi Fav Mod: Venison front Bumper mod Location: Pennsyltucky Posts: 1,424
IWSTI Addict since: Jun 2007 Trader Rating: (2) | I was *attempting* this install tonight and I ran into a problem. Got all of the bolts loose except for the stud on the driver's side. It is double-nutted, but it is not budging. It soaked with PB for about an hour, no luck. I loosened the double nut to expose 3-4 threads of the post on the INSIDE (towards the diff.) I sprayed again and will let it sit overnight. Anyone have ANY suggestions??? For the outrigger bushings, the thin bushings are for the STi, correct? I thought I remember reading a post in here about someone swapping the thicks out for the thins with better results... Yes/No/Maybe? Thanks in advance!!! This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 | |
| Iron Fisted | Quote:
| | #3 |
| Gold Member
IWSTI Addict since: Jun 2007 Trader Rating: (2) | Thanks, but...I've read it so many times I almost have it memorized. Step 4 in the instructions... Yah, I'm a dork. |
| | #4 |
| STI Driver | I ran into the same problem when installing the rear diff mount bushings on my car and I was also using PB. My crappy 17mm Metwrench brand wrench wasn't long enough (didn't have the torque) to remove one of the studs. I bought a stronger/longer 17mm wrench and it easily loosened the stud. I hope my post wasn't redundant, just offering a suggestion based on my experience. |
| | #5 |
| Senior STI Driver Car: RBP 05 2.5RS Wagon Fav Mod: Group N Lateral Link Bushings Location: Powell, OH Posts: 319
IWSTI Addict since: May 2007 Trader Rating: (0) | To answer your other question, the thinner large diameter bushing is for the Forrester. The thicker large diameter bushing goes on top of the outrigger and the thicker small diameter washer goes on the bottom of the outrigger. |
| | #6 |
| The Next Petter Solberg Car: '07 SWP STi Fav Mod: NEW BRAKES!!! Location: Jacksonville, FL Posts: 909
IWSTI Addict since: Feb 2007 Trader Rating: (3) | Double wrench it. No need to buy longer wrench if you are in a pinch. OOh im a poet and didn't know it. Seriously though i rememer installing this had to double wrench that bolt |
| | #7 |
| Black Dragon STI Car: 07 OBP STi 03WRB WRX Fav Mod: My whole suspension Location: Columbus, OH Posts: 1,702
IWSTI Addict since: Jan 2005 Trader Rating: (0) | Have you tried liftng the diff with a jack a bit? It should be supported anyways so it doesn't drop onto the exhaust, but the stud might be binding now that you've removed the other one. |
| | #8 | ||||
| Gold Member
IWSTI Addict since: Jun 2007 Trader Rating: (2) | Quote:
I am on my way back out, hopefully I'll figure something out! | ||||
| | #9 |
| Authorized Vendor | There is no set order on the outriggers. Just try different combos. On the stud - if it will not loosen then heat it up with a torch, and let it cool. Or put a punch on a couple of the flats for the nut and smack it with a hammer. I would say to normally to the punch on the end of the stud, but it's hard to get to on that one. |
| | #10 |
| Gold Member
Car: 05 Subaru WRX STi Fav Mod: T2s and Recaros Location: Allentown, PA Posts: 3,328
IWSTI Addict since: Oct 2005 Trader Rating: (7) | Good mod to have on your STi, you'll be pleased with the result. |
| | #11 |
| Amateur STI Driver Car: 06 STi #86 STU Location: Ft. Worth, TX Posts: 31
IWSTI Addict since: Jul 2007 Trader Rating: (0) | I had no issues when I did mine a month or so ago. I didn't use a normal wrench to break the diff studs free though, 2 ft. breaker bar + 17mm deep socket ftw!! Take your time and use the right tools, those studs are in there pretty good. As for the outrigger bushings, I used the think one as I understood the thinner one was for the GC8. I have been very pleased with this mod as I'm sure you will be too. |
| | #12 | |
| Spec C Club | Quote:
One tip for getting out the rear diff bushings is dunk them in warm soapy water, they will pop right out. | |
| | #13 |
| Gold Member
IWSTI Addict since: Jun 2007 Trader Rating: (2) | Got the stud loose. Time to buy a breaker bar because this is the 11ty millionth time I've needed one... Had to pull the exhaust out, axle back section of the XR1 I put in the other weekend... ...to drop the diff enough to get the bolts out. Thanks for all the suggestions on that stud. I hate being 100% clueless on how to approach a problem like that, but it worked out. Now I need to get it all back in! ![]() As for the outriggers, I installed the thin bushes, but it is easy enough that I can swap them back out. I might just do it anyway. Don't think I'll get to my TiC tranny crossmember bushes today |
| | #14 |
IWSTI Addict since: Jul 2007 Trader Rating: (0) | Glad to hear you got it all apart. No toolbox should be without a good size breaker bar. $25 well spent in my book. At any rate, good luck getting it all back together and enjoy! |
| | #15 |
| Gold Member
IWSTI Addict since: Jun 2007 Trader Rating: (2) | This ad is not endorsed by this member. Please register or login to hide this ad. |
