Old 04-14-2008, 06:48 PM   #1
Trader Rating: (48)
Default Power proven bragging, but for suspensions
We have all this power proven stuff for, well, power, but what about suspension?
I'm not shooting down the power stuff - there's a lot of guys doing AMAZING things with these motors, and coming up with ideas I would never think of. I'm just wondering if we can do the same for suspensions in some way.
I'm all for a set of easily defined and understood metrics (like HP and torque are to power), and a way to consistently measure them.
I'm thinking along the lines of peak G's and sustained G's, but I'm also thinking along the lines of a full circle diagram showing lateral and long. G's.
Any input along these lines of thinking would be greatly appreciated.
Old 04-14-2008, 06:59 PM   #2
Car: Your STi ;)
Fav Mod: Everything
Default Re: Power proven bragging, but for suspensions
How about track records
Siegel
Old 04-14-2008, 07:35 PM   #3
Trader Rating: (48)
Siegel
Problem there is not everyone has the time, budget or track within range. I'm thinking along the lines of peak G's, at X speed, over Y time or something like that.
Old 04-15-2008, 03:03 AM   #4
oMgWTFpewpew
Fav Mod: grip.
Send a message via AIM to chaos311clarity
what would be the standard method of measurement?
Old 04-15-2008, 03:27 AM   #5
Car: 05 Subaru WRX STi
Fav Mod: Coilovers and X-Brace
I think we should use our rally wing for this purpose of testing. simply record how many wendy's double bacon cheeseburgers can stick to the wing during a turn before sliding off. mmm wendy's.
Old 04-15-2008, 03:36 AM   #6
Fav Mod: a garage
- G-meter plots
- A standardized slalom of cones with X spacing and x distance from the first cone as a standing start.
- Highest held G-s (instantaneous mean nothing)
- most busted kidneys
Old 04-15-2008, 06:39 AM   #7
Car: Your STi ;)
Fav Mod: Everything
Everybody should get one of these:
Amazon.com: Escort Passport GT1 G-Timer Vehicle Performance Computer with Basic Feature Set: Electronics
Then you could have real figures (and they're only $35, I have one and it works surprisingly well)
Siegel
Old 04-15-2008, 06:56 AM   #8
Siegel
Done. I love a bargain, thanks for the link! (And if we're all using the same product, hopefully results will be comparable.)
I don't see it doing average G's or logging anything more than 0-60 runs, so the best we'll be able to compare is peak lateral G's. That right? And the premium version will show you the "traction circle", which is the sum of G forces in all directions, which is very meaningful... but it won't data log that number. The 10 runs it records are only straight-line logs.
For those curious, here's the manuals for the $35 and $70 versions, respectfully:
http://www.escortradar.com/pdf/gt1manual.pdf
http://www.escortradar.com/pdf/gt2manual.pdf
Edit #2: Cancelled Amazon GT1 order and bought the GT2 model on eBay for $51+$8 shipping!
Escort Passport GT2 G TIMER/METER FAST SHIPPING! - eBay (item 260229070366 end time Apr-20-08 09:36:50 PDT)
Edit #3: Just to throw some numbers out there, back when I was racing my Mazda6, I had the original G-Tech. It told me I was peaking around ~1.16G's lateral G's, and I'd say holding 1.1 (but again, it wouldn't calculate an average). This was on the original Falken Azenis RT-215.
Old 04-15-2008, 12:16 PM   #9
Car: Black 06 STI
Fav Mod: Seatbelt fix, site avatar delete
I have a G-tech unit that I've been meaning to hook up!
antonch is offline   Reply With Quote
Old 04-15-2008, 12:37 PM   #10
Car: Black 06 STi
Fav Mod: Whiteline Control Springs
Call me crazy, or naive, but isn't there a circle+speed test that does this? We would need some nice flat space to drive around on like a track or a parking lot. I'm talking about what they do in the option DVD episodes. I think they set the circle, and then drive around it at the fastest speed that doesn't loose grip. Then, average sustained G's are calculated from the time.
Seigitor is offline   Reply With Quote
Old 04-15-2008, 01:38 PM   #11
Trader Rating: (48)
there's always the max-q, but that's pricey.
Robot - any thoughts on your little G-meter dealie from your dash kit?
The circle is good, but doesn't measure transitional response (ie side to side). If all I wanted was SICK numbers in one direction at a constant speed I'd unhook the bars and go to town letting the suspension load slowly.
Old 04-15-2008, 01:58 PM   #12
GT R US
i'm digging this whole concept. what a coincidence...i have completely new suspension to wring out.
Old 04-15-2008, 02:03 PM   #13
jph
i have a GtechPro RR hooked up.
and can't seem to get anywhere near the lateral G's that i was able to do in my modded mx-5
TiC, i need coilovers and atomic fireballs
J.
Old 04-15-2008, 02:59 PM   #14
Car: 06 Stage 2 STI
Send a message via AIM to ESmooth
So by throwing on my hoosiers and laying out some VHT will I automatically win?
ESmooth is offline   Reply With Quote
Old 04-15-2008, 04:19 PM   #15
Fav Mod: a garage
I have usb key and to laptop datalogging working right now. In a few minutes I'm going to see the max sample rate I can force out of my setup.
BTW the Maxq is actually a relatively good deal for the hardware you get. The GPS receiver is where most of the money goes.
