Old 04-30-2008, 05:27 PM   #46
Car: RBP 05 2.5RS Wagon
Fav Mod: Group N Lateral Link Bushings
Default Re: Power proven bragging, but for suspensions
What we really need is something like a track. Say, and airfield. Then, we need to send all the cars there to be driven by a consistent driver. Say, a tame racing car driver...
williaty is offline   Reply With Quote
Old 05-07-2008, 07:27 AM   #47
Car: 05 STi WRB
Fav Mod: GC-06Hs & RE-01Rs
The Stig dude, and cool thread idea free bump.
o0)FuNkTrAiN(0o is offline   Reply With Quote
Old 05-07-2008, 10:26 AM   #48
Trader Rating: (50)
Tony took a ton of Max-q data at the track, and Rob is compiling it into a more readable format.
Actually, Rob tells me it's done and on Tony's laptop....... which he forgot today.
I'll have him post it up so we can start to get an idea of how things are measured with it, and what we would come up with a standard.
Oh, this was for the 08 STi as well.
Old 05-13-2008, 11:07 AM   #49
Car: 05 STi OBP
Fav Mod: Data Acq System
Where is the data at man!!!! I got some max q data (from the chepo MaxQGPS unit, didn't have my MQ200 hooked up) and can send it out. My car is stock power, stock suspenions. Only mods are track pads, racing brake slotted rotors and the Sparco bar. Tires are 245/45-17 Azenis 615's.
I am hoping to throw on Pink springs (JDM) and the TiC frame bars and do some parking lot comparisons (runing over a bump, skid pad etc.) to compare performance.
MGizzle is offline   Reply With Quote
Old 05-13-2008, 12:09 PM   #50
Trader Rating: (50)
We'll work on getting that on the site today. Just trying to figure out the best format.
Old 05-13-2008, 12:21 PM   #51
Car: 2008 Pinarello FP5
How does the MaxQ output data?
- Andrew
RaceComp Engineering is online now   Reply With Quote
Old 05-13-2008, 02:41 PM   #52
Trader Rating: (50)
- Andrew
I believe it's proprietary, but the viewer software is free so you could grab the data file and "playback" the laps.
Old 05-13-2008, 02:57 PM   #53
Trader Rating: (50)
It has its own viewer that outputs to an HTML page. It gives you G data and lap times as well as the lines you took around the course. You can also overlay your line on a google earth image of the track. It's pretty cool.
If we can get our FTP server working, we'll get the images out here.
TOny
Old 05-13-2008, 03:15 PM   #54
Trader Rating: (50)
Some links:
Lap 1
Lap 2
Lap 3
Lap 4 (I think this was cool down)
I'll post up links to the data files later.
-Clint
Old 05-13-2008, 06:20 PM   #55
Car: 05 STi OBP
What MaxQdata are you guys using? Just the cheap gps one or the full unit with OBDII and inertial sensors??
Anyway, the data is propriatery but you can export it into EXCEL, hence you can do your own analyzing. The MaxQ software is free though so anybody can view TiC's data or anybodie elses. The MaxQ stuff though is pretty sweet and in my opinion it is worthless when you look at lines etc. because the GPS drift can be as much as 10ft. However, comparing lap to lap and somebodies data at the same track to yours gives you very good input.
Old 05-14-2008, 03:55 AM   #56
Trader Rating: (50)
We are using whatever version Kartboy sent us....the cheap version. I would love to have the one that interfaces to the OBD system, but it's out of our price range at the moment. We have the excel files for the data if people want to play with it.
Keep in mind, these were not all out laps. These were done on my last run group of the day at which point I was having braking issues. The straights are not all out at all, but most of the corners were 8/10's or so.
Tony
Old 05-14-2008, 11:14 AM   #57
Car: 05 STi OBP
Yeah, I feel you on the OBD system. YOu have no idea how much more info it gives you about YOU and how you drive the car.
Anyhow, what braking issues did you have?? I melted some Carbotech XP10's on my STi at Waterford last weekend on Racing brake slotted rotors. I am hatting aftermarket rotors and pads (street) right now. My whole freaking car vibrates. At the track however the braking was a lot better then ever before but that resulted in significantly more heat and my front left brembo finally bronzed up. Looks completely different than the other 2. Sucks.
Could you shoot me your MaxQ data over (the actual mqd file). My email is mgrebovic@gmail.com. I can shoot you my data back from Waterford on the stock 05. Later man.
Old 05-14-2008, 01:43 PM   #58
Trader Rating: (50)
I can answer that - cooked the rotors. Just didn't have enough air to them. Need to get more in there.
-Clint
Old 06-19-2008, 10:45 AM   #59
Trader Rating: (50)
To revive this thread:
Here is some additional data from a track day on Tuesday at Autobahn South. Overall it was a good day, but I still had problems with brake fade. I am stepping up to a high heat compound for next time. Since the last day in the 08, I have added some camber bushings in the rear and aligned the car with 1.5* in the front and 1 in the rear. It felt much better, but still needs more front camber.
MaxQData autobahn 4-28tony006-QviewL001S01
Tony
Old 06-19-2008, 10:58 AM   #60
abracious
Fav Mod: Track time
Tony
If you think that was brake fade- you have to ride in my car next time. I felt like I was driving with Hyuandai brakes after my laps with you.
