Old 04-07-2008, 01:03 PM   #1
Car: '04 Sti
Default Suspension gurus please help!
I have been looking for answers to these ?'s for a few days with no luck:
The REAR struts from an '05 will bolt right up to my '04. Yes/no?
Should be able to swap '05 FRONT cartridges into my '04 front strut housings?
Also, is there any difference between prodrive springs for an '04 and '05 STI?
Thanks all
'04 Black STi is offline   Reply With Quote
Old 04-07-2008, 01:41 PM   #2
Fav Mod: T2s and Recaros
Default Re: Suspension gurus please help!
Rear struts will work.
Yup, cartridges should fit fine.
Yes, the 04 spec was way too soft (softer than your stock springs according to some). You'll want the 05 spec.
Old 04-07-2008, 01:58 PM   #3
Car: '04 Sti
Word, thanks!
Old 04-07-2008, 03:59 PM   #4
Car: '04 Sti
And an '05 thru '07 STI have the same setup?
Old 04-07-2008, 04:02 PM   #5
yup..
Old 04-07-2008, 04:36 PM   #6
Car: 2008 Pinarello FP5
04-07 fronts are the same.....and the 07 rears were slightly revised.
mw
Old 04-07-2008, 04:38 PM   #7
Car: '04 Sti
thanks again guys!!!
Old 04-08-2008, 09:13 AM   #8
One thing is for certain, when an 06-07 clunks in the rear its not the same sound as the 04-05 clunk. Its a much more subtle sound, and it can be eliminated easier also.
mw
Old 04-08-2008, 07:29 PM   #9
Photography Mod
mw
hmmm...good to know.
Old 04-08-2008, 08:30 PM   #10
Car: '04 Sti
So, is taking off the bottom nut off the strut to repack the grease essentially all I need to know to switch out the cartridges, or is there more to it?
Old 04-09-2008, 02:52 AM   #11
well yeah but of course you have to disassemble the rears first..and then yeah remove those nuts. There is another thread that shows this around here.
mw
Old 04-10-2008, 09:02 AM   #12
Car: '04 Sti
mw
I can't seem to find this thread. Any one that helps gets a virtual cookie
Old 04-11-2008, 02:16 AM   #13
Car: '04 Sti
mw
^^^This
Old 04-11-2008, 11:04 AM   #14
Car: '04 Sti
mw
help me find this thread plz
Old 04-11-2008, 11:39 AM   #15
PM me with your email and i'll send you a file.
- Andrew
