Old 04-07-2008, 05:36 AM   #1
Default swaybar settings?
Ok I have a few braces, coilovers, and f/r cobb sways. My car is pushing a little on corner exit. Should I make the rear sway tighter or softer to minimize understeer? Again the understeer is minimal.
normansti is offline   Reply With Quote
Old 04-07-2008, 05:45 AM   #2
Default Re: swaybar settings?
Firm up rear sway (shorten arm length) = less understeer / more oversteer
Old 04-07-2008, 06:24 AM   #3
Car: 2008 Pinarello FP5
Also, small things like looking further ahead sooner will help that also......its a small thing, but it works.
mw
Old 04-07-2008, 12:43 PM   #4
What if I replaced the cobb front sway and put the stock sway back on? Would this help or would it hurt my handling more then help it?
Old 04-07-2008, 01:44 PM   #5
Fav Mod: T2s and Recaros
Before you change bars and all that, what is your alignment set to?
Old 04-07-2008, 02:40 PM   #6
Car: 04.5 STi- PSM
Fav Mod: learning how to drive
mw
true story. The tight turn around at this weekends autox was givin me a lot of problems until I started lifting my head up and looking further ahead. It didnt take all on the push but it helped quite a bit
misterwaterfallin is offline   Reply With Quote
Old 04-07-2008, 06:31 PM   #7
-3front -1.5rear
Old 04-07-2008, 06:49 PM   #8
-3front -1.5rear
ok cool, thats right on
try bumping up the rear sway before touching the front
Old 04-08-2008, 03:39 AM   #9
did that yesterday. We will see how that turns out. I also went a little wider in tire size to 245's I dont know if thats going to help though
Old 04-08-2008, 09:49 AM   #10
always....to some degree.........
mw
