Old 07-19-2004, 02:41 PM   #1
Fav Mod: GT-35R
i decided to get the sti imitation strut tower braces from ebay, got them for $57 shipped, Thanks Scuba for finding the good deal.
Install was straight forward, took probably 2.5-3 hours, but i was working slow. i could see the install only taking 1.5-2 hours.
can't say i feel a huge difference yet. the rear does feel a bit more connected or rigid, not much difference for the front. i was not expecting much. i need to take a couple of corners i know of and see if higher speeds make more of a difference.
overall i am happy, the quality is great. i honestly can't see spending much more for thses parts. i could see the cusco rear triangle shaped bar working a bit better but it is much more $$
for me it was definetally $57 well spent.
now for the later links and trailing arms to be installed!
cnstman is offline   Reply With Quote
Old 07-19-2004, 02:58 PM   #2
Fav Mod: GT-35R
just found a killer install link in the mods forum. it is a good writeup
http://www.filtsai.com/sti/strut_bars/
Old 07-19-2004, 03:59 PM   #3
Rev
STI Guru
Car: 06 V70R
Send a message via AIM to Rev
Agreed with the Replicas. Even though you didn't feel much of a change (because you had the pinks already), the extra stiffness is there. You won't feel much of a difference with the lateral links. I felt the change with the strutbars, but not much with the l.links.
Old 07-19-2004, 05:16 PM   #4
Send a message via AIM to stiperformance Send a message via Yahoo to stiperformance
I got my replica bars on Ebay for about the same price 6 months ago. They are actually very decent quality for the price. The welds are very good and they fit nearly perfect. Can't complain...they work!
stiperformance is offline   Reply With Quote
Old 07-19-2004, 08:20 PM   #5
Fav Mod: GT-35R
after taking my normal comute home, and taking some high speed corners, i can say they do stiffen up the rear quite a bit. i am even more happy now!
Old 03-06-2008, 05:56 PM   #6
Car: 05 CGM Subaru WRX ST
Default Re: Ebay Strut Tower Braces
I was very dissapointed with my ebay front and rear strut bars and ended up spending a little more on Tien ones. They look great and are very light, but I don't think the front one would work at all because I was able to bend mine pretty easily. Glad yours worked out for you though!
rosco110 is offline   Reply With Quote
Old 03-06-2008, 06:25 PM   #7
Fav Mod: HKS CARBON TI
i have the ebay ones too. Dont look the best but they get the job done. Paid 15 each
WESTI is online now   Reply With Quote
Old 03-06-2008, 06:39 PM   #8
i eat cones
Fav Mod: catless
Trader Rating: (13)
my ebay front one didnt fit
im gonna try the rear one some day.
Old 03-06-2008, 07:37 PM   #9
Car: 04 sti
Fav Mod: enginuity tuned
both of mine fit and the rear strut bar definitely tightened up the rear end.
Old 03-06-2008, 07:42 PM   #10
my rear one was a biatch to get on but it eventually did fit
Old 03-06-2008, 09:12 PM   #11
just put my tien ones on this evening and took it out for a spin. The car does feel a little tighter. I must say that I'm VERY impressed by the quality and fit of the Tien strut bars.
Old 03-06-2008, 09:49 PM   #12
My thought on it is. If it ain't a pita to get in, then it's not stiffning up a whole lot. My ebay front "fit" but definatly need some fanagling to seat right. It sits SUPER snug, and I belive that has something to do with its overall stiffining. Weight transfer is much more direct and precise. Guys with good tires and other body stiffning will benifit more. But you cant say no to $57 shipped for front and year, it's a no brainer.
Old 03-07-2008, 05:25 AM   #13
i have the SPT (steel) bars front and rear. front one didn't do
much, but the rear took out essentially all of the rear window
creaks.
abby normal is offline   Reply With Quote
Old 03-07-2008, 07:00 AM   #14
Car: 05 W/G STi
Fav Mod: White Headlights
Send a message via AIM to dannyc1225
the rear does a lot on these cars (since its basically bracing a rectangle which is easy to deform) an even better solution is the X-brace. The front is a different story, it has the firewall which adds a lot of shear strength to the front so the strut towers are less likely to move
A little OT but i got those fender cowl braces a while ago and the entire front end of the car feels a whole hell of a lot more supple under bumpier roads and response is improved a tad.
dannyc1225 is offline   Reply With Quote
