Old 03-29-2008, 11:57 AM   #1
Car: Blue w Gold 07 WRX S
Fav Mod: Tune
Default Do I need a F/R Strut Bar? Best F/R Strut Bar?
I was wondering of putting a front and rear strut bar. Do i need one? Does it help in handling?
I've searched for the best strut bars f/r and didn't find anything. Which f/r strut bar is the best?
STIstud2k7 is offline   Reply With Quote
Old 03-29-2008, 11:59 AM   #2
i eat cones
Fav Mod: 18x8
Trader Rating: (18)
Default Re: Do I need a F/R Strut Bar? Best F/R Strut Bar?
front is not needed, just cosmetic.
the rear does help a little.
people like the cusco ones, jdm sti ones, etc.
there are alot.
Szumita is online now   Reply With Quote
Old 03-29-2008, 12:11 PM   #3
Fav Mod: Ring-Shaped Reinforcement Frame
The ebay ones are realllly cheap. You could get those just to try them out...
USNSTI is online now   Reply With Quote
Old 03-29-2008, 12:21 PM   #4
Car: 07' OBP STi
Send a message via AIM to azndrgnkid
Most people will say it is not needed, or at least it is the least helpful part(s) for the money on suspension. I personally have done it and think the result are good. But at the same time I added the strut bars together with sway bars in combination and most people will contribute it to the sway bar doing making most of the difference. I got Tein bars (front and rear) because they are fairly cheap and does the job, but there alot out there. Search some more and I'm sure you can find some details on it. Brands like Cusco, SPT/Sti, Tein, are all fairly common and easy to get your hands on.
azndrgnkid is offline   Reply With Quote
Old 03-29-2008, 12:28 PM   #5
Car: '05 CGM STi
Unless you really autoX your car and have other serious suspension mods (stiff coilovers, etc.) a front strut bar will do LITTLE for you. As far as the rear, they do have an effect but the best thing you can do to the rear is get an X-brace. I have yet to hear a single bad thing about them and you notice it right away.
Old 03-29-2008, 12:33 PM   #6
Car: 06 subaru wrx sti
Fav Mod: royal purple
what does the X-brace do ?
disturbed1 is online now   Reply With Quote
Old 03-29-2008, 05:01 PM   #7
Fav Mod: Tune
Basically, I don't need any Strut bars if I am not into AutoX?
I don't need a strut bar set if I don't aftermarket coilovers, right?
THe rear strut bar will make a difference and the front strut bar won't make too much of a difference?
I'm not into AutoX racing but I will like to make the handling better as in when switching lanes with a little turn. I'm not sure if anyone understands what I am trying to say. EVO's have a stock Strut bar and their handling is really stiff, it turns better when going 40MPH. Did I make it understandable?lol
Old 03-29-2008, 05:16 PM   #8
Fav Mod: T2s and Recaros
STi Suspension Buyers Guide
Old 03-29-2008, 05:59 PM   #9
Fav Mod: The Newest One!
Look into some sways, they will make much more of an impact
fourseasonsandles is online now   Reply With Quote
Old 03-31-2008, 01:52 AM   #10
Fav Mod: Tires and Brakes!
^^ I agree
A buddy put a front strut bar on his car and have yet to feel a difference in handling. Cusco is nice bling though
Save your money for sway bars
gosu is offline   Reply With Quote
Old 03-31-2008, 02:11 AM   #11
Car: Silver 05 WRX STi
Fav Mod: Advan RGIIs
I bought a Cusco Ti bar mainly because they were discountinued as of recent. While it does not contribute a lot I do believe it helps stiffen the body a little.
mdefalco25 is offline   Reply With Quote
Old 03-31-2008, 12:32 PM   #12
Car: '06 Subaru WRX STi
Fav Mod: X-brace
To answer your questions frankly, the X-Brace works - very well in fact.
Strut braces are basically made for every single vehicle that has the slightest performance intentions (i.e. Corolla). Strut braces are cheap to make, cheaper to install, and look cool. That does not mean that they work in every case.
The STI (or Impreza) is just this case. Typical strut braces, as well as the recent C-Pillar braces, do not work - sorry. Take a look at the front strut towers on your car, they are adjacent to and part of the firewall - an area that is already very well structurally reinforced. Compare this to a 350Z, 3 Series, or Corvette where the struts are much further forward - in this case, a front strut bar is crucial and lends to a big improvement in torsional rigidity.
The rear strut bar faces a similar fate in case of the Impreza thanks to a terrifically built chassis and rally racing intentions.
On some vehicles the additional "X" would just be added weight; however, with the Impreza the X-Brace is the required design to achieve optimal torsional improvements (11%).
Quite simply: think of the X-brace as the rear strut bar for a WRX/STI.
Thats it.
This video shows what happens without an X-Brace (notice the brace is unbolted). Watch the movement of the chassis which is effectively eliminated by the brace.
CARLAB Development - X-Brace
CARLAB STi is offline   Reply With Quote
Old 03-31-2008, 01:43 PM   #13
Trader Rating: (50)
Thats it.
You guys wouldn't happen to have done any shaker tests with various other parts have you? I'm curious if we can finally end the argument back and forth on stuff like strut bars.
Turninconcepts.com is online now   Reply With Quote
Old 03-31-2008, 02:03 PM   #14
Fav Mod: X-brace
We have tested the torsional rigidity using "shaker tests", of more than 8 different designs. This included an oversized front strut bar (so big the hood would not close), horizontal rear strut bars, v-braces, and various undercar braces.
This is the only design that we have tested that supplied noticeable results (on paper and in the arse).
Note: We have not tested the fender braces, which based on the reviews we have read - likely does work.
Old 03-31-2008, 02:06 PM   #15
What chew LookN @
Fav Mod: DP..CATBACK:)
The video does show some conclusive evidence that there is pretty good movement going on there without the bar bolted in.
flat4t is offline   Reply With Quote
