Old 03-27-2008, 07:40 PM   #1
Car: OBP, 2007, STI
Fav Mod: Protune
Default Prodrive springs, now thinking going lower
greetings,
I've an 07 STI and for about the past 10 months I've been riding on the Prodrive Springs. They eliminate the compression and rebound issues on the stock springs. The only issue is I'm thinking I can easily drop the car another inch. I don't think I want to go coilover as this is a DD. Perhaps just another spring as comfortable and functional as the Prodrives just about 1/2 to 1 inch lower.
Sincerely,
Jason
OBPSTI is offline   Reply With Quote
Old 03-27-2008, 08:10 PM   #2
Photography Mod
Default Re: Prodrive springs, now thinking going lower
im not sure you're going to find such a thing. If anything, look at the RCE Blacks.
Parker is online now   Reply With Quote
Old 03-28-2008, 04:50 AM   #3
Moderator (v0.9 Beta)
Fav Mod: banhammer
Just get RCE lowering camber plates in the front and call it done.
Old 03-28-2008, 04:26 PM   #4
Isn't that wait Pinks would do for you?
t30wrx is offline   Reply With Quote
Old 03-28-2008, 04:32 PM   #5
+2 for the lowering camber plates. Also get you some nice camber
Old 03-28-2008, 04:42 PM   #6
Fav Mod: Ring-Shaped Reinforcement Frame
Old 03-28-2008, 06:09 PM   #7
Originally Posted by OBPSTI View Post
greetings,
Sincerely,
Jason
What makes you think that? An inch lower and you will have used up over two-thirds of your bump travel at ride height. (Your Prodrive springs already rest the car on those included bump stops.)
Old 03-28-2008, 06:58 PM   #8
Car: UGM 07 STi
Fav Mod: Cobb DP and Stg2
I have no way to back this up other than I did the install myself, but I highly doubt the prodrives are making me and everyone else ride on the prodrive bumpstops. The stock ones maybe
Hirogen is offline   Reply With Quote
Old 03-28-2008, 07:41 PM   #9
Car: WRB 06 WRX STI
Fav Mod: Stage 2
I did the same thing, installed prodrives and wanted a lower drop. Switched to RCE yellows and am a lot happier, actually the front still sits a little high. Considering the lowering plates only lower 3/8's of an inch, I don't think that'll solve the OP's issue.
SonicBoom is offline   Reply With Quote
Old 03-28-2008, 08:25 PM   #10
Car: '05 CGM STi
Get the RCE Yellows, and your set.
CGMDan is online now   Reply With Quote
Old 03-28-2008, 08:26 PM   #11
Car: 07 SWP STi
Fav Mod: Perrin Exhaust
I'm going to be putting my prodrives on very soon, and will also be putting the RCE lowering camber plates on as well. I can take pictures when the install is done if you would like.
Dragicon is offline   Reply With Quote
Old 03-29-2008, 03:26 AM   #12
The Prodrive bump stops are barely shorter than stock- just a small fraction of an inch different in length. They feel better because of the different rate of the bump stop, not because they are shorter.
Old 03-29-2008, 03:31 AM   #13
STI Guru
Fav Mod: grip.
get some tanabe's lol..
just kidding... rce yellows are generally looked at as the lowest functional springs.
Old 03-29-2008, 07:31 AM   #14
Car: 2oo5 cgm STi
I guess 1/4" is a fraction... I wouldn't say it is insubstantial. The tapered portion is mostly void iirc.
austinpike is online now   Reply With Quote
Old 03-29-2008, 07:47 AM   #15
STI Guru
Fav Mod: grip.
i wonder what the ohlins bump stops look like
