Old 03-25-2008, 08:15 AM   #1
Car: 05 OBP STI
Default my alignment
i got an alignment today after i installed RCE yellows, swaybars and some bushings. i went to the dealer but they said the my car was too low so they didn't do it so i went to a goodyear shop to get the alignment done. what do you guys think is it a good alignment?
wpwm020 is offline   Reply With Quote
Old 03-25-2008, 08:20 AM   #2
Default Re: my alignment
Was your goal to minimize tire wear?
Old 03-25-2008, 08:38 AM   #3
Car: 05 OBP STI
no i just wanted a regular alignment. what's wrong with it?
Old 03-25-2008, 11:50 AM   #4
Fav Mod: Gram Light 57F's
Send a message via AIM to jordanretro1223
You probably could have gotten more front camber. The front bolts are capable of more. The toe looks fine but the actual numbers could be closer to 0 degrees.
jordanretro1223 is offline   Reply With Quote
Old 03-25-2008, 12:27 PM   #5
Nothing is wrong with it (though their SAI measurement looks off). The minimal front camber is good for tire wear, but most aggressive drivers here would recommend a bit more.
Old 03-25-2008, 01:37 PM   #6
Car: 05 OBP STI
i think the mechanic didn't adjust camber at all because the # for before and actual are the same and for the SAI he said that he couldn't adjust it because i have aftermarket parts.
What's SAI and that does it do?
Old 03-25-2008, 07:06 PM   #7
Car: White 05 WRX STi
I prefer larger camber up front personally, but since the toe is fine, and you did it in goodyear, I would have to say it's ok
But since you have RCE yellows and swaybars, i guess you are at least a little bit concern handling of your car, and I would suggest you get a bigger camber up front next time you do your alignment
treefolk is offline   Reply With Quote
Old 03-26-2008, 03:17 AM   #8
Car: 05 STi - Black
Fav Mod: No Lien
What exactly did you ask the tech to do? Or did you not ask anything?
In my experience, if you don't ask for something specific, they'll tweak it until all the values are green. Which means nothing will match left to right, and your car will drive like crap.
Always ask for specific values. Always.
Old 03-26-2008, 08:26 AM   #9
Car: AW 06 STi
Fav Mod: GReddy Spectrum Elite
Your alignment is fine.
You only have a 0.3* difference in caster and rear camber. You can't even feel a caster or camber induced pull or you would mentioned it.
Any more camber and you will be buying tires even quicker than you already do.
If you are looking for a track alignment, you could probably could have used more negative camber in the front, and more negative toe.
But without tire temperature data, you would just be guessing.
As far as your front and rear toe settings being "closer to zero", -0.03* is a "toe out" setting of THREE HUNDREDTHS OF ONE DEGREE.
My car is a 70 mile a day D.D.
I aligned mine to -0.3 degrees Fr. camber and + 0.04* toe, and -0.4* rear camber with +0.02 toe. I am not concerned about handling at the limit.
I have a toddler in the back, and I have to drive in the snow.
I have excellent grip and even better tire wear.
Align it for what it's used for.
chayashi is offline   Reply With Quote
