Old 03-23-2008, 12:31 PM   #1
Default Thinking of using Motul 300 Tech grease to regrease struts, any thoughts?
Going to be replacing bumpstops in front soon and wondering how the Motul 300 Tech grease is for regreasing the struts? I'm curious how the o-rings and seals will fair, the bottle says for extreme pressure and also that it is a lithium complexe. Any tips on regreasing?
Turbopilot 2.5 is online now   Reply With Quote
Old 03-23-2008, 02:33 PM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Thinking of using Motul 300 Tech grease to regrease struts, any thoughts?
EP usually means sulphur which is bad on some stuff.
Now with that being said we used Neo HP800 for the job and it's also an EP grease and seemed to work just fine.
With that being said - give it a shot.
Turninconcepts.com is online now   Reply With Quote
Old 03-24-2008, 01:15 PM   #3
Fav Mod: stock clutch
Turbopilot - are you trying to reduce noise as well?
oce420 is offline   Reply With Quote
Old 03-27-2008, 02:18 PM   #4
Car: 2008 Pinarello FP5
I would use Mobil 1 bearing grease. Many on here have used it and the last works for a while.
mw
Old 03-28-2008, 06:57 AM   #5
Car: '07 STI
Myles, would that be a decent general-purpose grease for not only struts/coilovers, but re-greasing swaybar bushings, etc.?
sparafucile is offline   Reply With Quote
Old 03-28-2008, 08:59 AM   #6
We use some hi tech crazy stuff, let me find out. Alot of times., I am out of the loop onthat stuff..
brb
Old 04-02-2008, 12:51 PM   #7
Car: 06 WRB STi
brb
Bump. I'd like to hear the answer to that as well.
webcrawlr is offline   Reply With Quote
Old 04-02-2008, 12:57 PM   #8
I ordered more today and will have to see what comes in.
Its made by Mobil 1.
mw
