Old 03-19-2008, 09:32 AM   #16
I Has a Turbo Timer
Fav Mod: Every single one!
Trader Rating: (23)
Default Re: C-Pillar Bar
^I have an Autopower roll cage, they have bigger piping to worry about = No passengers !
Old 03-19-2008, 10:18 AM   #17
Teh Other White Meat
Trader Rating: (22)
True true
Old 03-19-2008, 10:33 AM   #18
Fav Mod: T2s and Recaros
I really wonder if this would make any difference on a car that already has an X-Brace.
Old 03-19-2008, 10:34 AM   #19
abracious
Fav Mod: Track time
Originally Posted by snorky View Post
After looking at this pic, it could dangerous on a DD with passengers in the rear. They could crack their noggin on that thing if you get rear ended.
This is not rear-passenger safe. Period.
Old 03-19-2008, 10:47 AM   #20
I Has a Turbo Timer
Trader Rating: (23)
For <$30 its worth a try. I think it may help, but not be an overwhelming difference. But, since you pay <$30, the difference per dollar is worth it. We shall all see!
Old 03-19-2008, 10:55 AM   #21
Trader Rating: (22)
The X-Brace makes an huge difference. I doubt there would be a noticeable difference. I agree, for $30 it couldn't hurt and the rear could use a little extra weight.
Old 03-25-2008, 08:15 PM   #22
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
I am going to be installing this tomorrow. Where do I need to set the seatbelt brackets? middle, top, or bottom setting?
B4RSTiwsnc is offline   Reply With Quote
Old 03-25-2008, 08:47 PM   #23
Trader Rating: (50)
Since you already have rear deck across the two C-pillars at the mid point I would set those high to move the bracing point up higher.
Old 03-26-2008, 08:17 AM   #24
Install took all of 10 minutes very straight forward. I will update on how it performs on the butt dyno
Old 03-26-2008, 09:12 AM   #25
I Has a Turbo Timer
Trader Rating: (23)
Nice......any feedback?
Old 03-26-2008, 10:19 AM   #26
Trader Rating: (22)
Mine just came in. Fake Carbon Fiber FTW!! I would recommend putting anti-seize on the telescoping bolts. I am also going to put flat washers on the mounting bolts and lock washers on the nuts.
I also just ordered one of these. It's marketed as a handle bar mount for motorcycles. It fits rails of dia .75" to 1". The C-pillar bar is .888":
Here's the website if anyone is interested. Just FYI: It's cheaper to get it through direct through them than the exact same ones on Ebay.: Camera Mounts @ RAM Mount
Old 03-26-2008, 10:29 AM   #27
I Has a Turbo Timer
Trader Rating: (23)
Nice!!! I couldn't do fake carbon fiber, but for the money its worth it right?! Anyone get feedback from the install? I am still at work, but I plan on installing it later today when I get it.
Old 03-26-2008, 10:48 AM   #28
Trader Rating: (22)
It doesn't look bad from far away. I got it in CF as more of a joke anyway.
I probably won't install mine until i receive the camera mount.
Old 03-26-2008, 10:52 AM   #29
abracious
Fav Mod: Track time
When'd you order snorky? I have yet to receive mine.
Old 03-26-2008, 10:57 AM   #30
Trader Rating: (22)
The 19th
