Old 03-14-2008, 05:22 AM   #1
Default Need to know if ST-203704s021 is real gourp n rear top mount # for an 07'?
The majority of part #s I've seen for group n rear top mounts are
ST-203704s020, is there any difference if the part # is ST- 203704s021? The only thing that is different is that the # ends in a 1 instead of 0. Need some advice I have a set on the way. thanks
Turbopilot 2.5 is offline   Reply With Quote
Old 03-14-2008, 09:35 AM   #2
Car: 2oo5 cgm STi
Default Re: Need to know if ST-203704s021 is real gourp n rear top mount # for an 07'?
I would guess they are the same thing, Subaru apparently makes minor revisions and changes the part number, for example the rear struts have been through 20360FE900, 20360FE901, and 20360FE902. 900 is what came on my '05, but the replacement for that part is now the 902 number.
Check the paint mark when they show up, the ones I had had a white splotch on them (vs pink for stock.) If they are white, that is a good sign, if they are some other color I should update this FAQ.
FAQ: how can I determine real JDM pink springs/group-N tops?
