Old 03-12-2008, 09:37 PM   #1
Car: 06 Subaru WRX STi
Default Wanting to get a realignment
Last time when I added a little bit of a bigger tire 245/40 on my 06 i got a simple alignment from goodyear. And the moment driving it i knew it could be better but not sure what error to get fixed. Here is the print out.
Old 03-12-2008, 09:37 PM   #2
Default Re: Wanting to get a realignment
This is on a stock setup and for a DD
Old 03-13-2008, 05:55 AM   #3
Car: 05 STi - Black
Fav Mod: No Lien
If you want the most out of your current setup, maximize your camber up front. You can probably get around 1 degree out of stock bolts, maybe a smidge more (right now you're running 0.3 degrees)
Ask for 0 toe all 4 corners. Right now, you have too much toe in the rear. I'm also surprised by the amount of difference in rear camber. Did you buy your car new?
Old 03-13-2008, 06:03 AM   #4
Fav Mod: Motor Mounts
Take it back and tell them that a .10 of a degree of toe is not acceptable...and while they are at it...dial in some more negative camber.
I thought that only .08 degrees was allowable...
polyol is online now   Reply With Quote
Old 03-13-2008, 09:56 AM   #5
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Wow, they didn't do much did they? Looks like they probably adjusted toe on the front only.
Tony
Old 03-13-2008, 10:10 AM   #6
jph
this is what i usually ask for;
Front: everything matched left to right.
max negative camber you can get, the same on both sides
max amount of caster you can get, the same on both sides
zero toe
rear: again, everything matched, unless your camber is non adjustable, you'll pretty much be stuck with what you've got.
SLIGHT toe IN, as little as possible, matched on both sides
if you have camber bolts in the rear, ask them to match it on both sides. -1.5 is a good starting point.
J.
jph is online now   Reply With Quote
Old 03-13-2008, 11:47 AM   #7
Yes new and never hit a curb or anything in its life.
Old 03-13-2008, 01:55 PM   #8
Car: 2006 STI
Fav Mod: Perrin Catback
Send a message via AIM to ChrisM623
Why is your camber up front at -.03?
Isn't OEM like -1.3?
ChrisM623 is offline   Reply With Quote
Old 03-13-2008, 01:58 PM   #9
jph
-1.3 is about the max you'll get without plates or bolts. that doesn't mean that subaru actually dials it in that way for you. there have been sti's that left the dealership parking lot with positive camber up front.
J.
Old 03-13-2008, 02:01 PM   #10
Car: 05 STi - Black
Fav Mod: No Lien
My factory alignment had very minimal front camber. A quick visual, and my treadwear was evidence of this.
