Old 03-12-2008, 08:29 PM   #1
Default 04 STI to RB320 suspensions switch POSSIBLE??? IF yes HOW???
anybody can tell me if is possible to put rb320 suspension on 04 STI??
if is possible what do i have to do???
and HOW MUCH WILL IT COST???
if NOT can you recomend struts for 04 STI (not fan of coilovers)
OHLIN struts is my choice but which one to get for street drive?? and where do i get it???
THANKS!!!
onlywiseman1 is offline   Reply With Quote
Old 03-13-2008, 06:16 AM   #2
Car: 04 sti
Fav Mod: enginuity tuned
Default Re: 04 STI to RB320 suspensions switch POSSIBLE??? IF yes HOW???
you would need the 6gun 5x100 to 5x114.3 swap kit. the kit is around $1000, and good luck finding a rb320 kit.
you could try tokico d-specs, koni inserts, or ohlins fps. pm racecomp engineering for info.
Old 03-13-2008, 07:46 AM   #3
Car: 05 STi - Black
Fav Mod: No Lien
You can probably get RB320 thru Cosworth, as they have recently announced themselves as the new Prodrive North American distributor.
You can get the kit for a measly 2700 bucks.
Old 03-13-2008, 09:54 AM   #4
Trader Rating: (50)
Why do you want the RB320 kit so badly? I wonder if the guts from the RB320 struts would swap over to the 04 sti strut housings?
tony
Old 03-13-2008, 07:59 PM   #5
well!! i just like PRODRIVE!!! i have their intake and exhaust and it's perfect for my taste!!!! and i've got to have rb320!!
by the way thank you for the recomendation for struts!!! REALLY bottom of my heart!!!
Old 03-13-2008, 08:01 PM   #6
I like Prodrive too, but we're talking major dough. Do the 5 x114 for more than just that suspension. You know you need new wheels with that, right?
Saabaru STI is offline   Reply With Quote
Old 03-15-2008, 10:56 AM   #7
HU??? so for both front and rear wheels???
Old 03-16-2008, 11:18 AM   #8
Car: 04 sti
yes, to make the rb320 a direct swap, you need to swap both the front and rear. while you're at it, you should buy a set of prodrive wheels.
Old 03-16-2008, 11:29 AM   #9
Car: 07 UGM STi
Fav Mod: Aux cord & Nitrogen in tires
^^ Like this...
LOL Sorry for being a whore
AP1toGDRev.G is offline   Reply With Quote
Old 03-16-2008, 11:32 AM   #10
Car: 06 Subaru imprezaSTi
Fav Mod: Prodrive
you'll need new brake rotors too.
steelgraySTi06 is offline   Reply With Quote
Old 03-17-2008, 12:19 PM   #11
Car: 2004 STi
Fav Mod: STi Recaro Seats
Why not just get Ohlins fixed perch with RCE blacks? That is just what I put on my 04 and it is a really amazing setup.
Jethro is offline   Reply With Quote
Old 03-17-2008, 03:35 PM   #12
Car: 07 UGM STi
I <3 ohlins...
Old 03-26-2008, 08:33 AM   #13
Car: 6-gun STi
Fav Mod: CNC !
The rears will bolt up just fine.
The fronts will need a thicker 05+ STi style upright on the knuckle. The only reasonable way to achieve this is using the OEM 05 STi knuckle, which will require you to use 05 hubs , which we machine with a 5x100 pattern. You will also need an ABS adapter which comes in our kit.
Our typical kit machines both the hub for 5x100 and the knuckle for 04STi style struts. You would only need the hub machined so your total hub kit would be less than the typical kit.
The un-reasonable way to convert would be to plug and redrill the top hole on your existing knuckles. Then have some spacers fabricated (with the 05 upright hole spacing) that would mount on both sides of the 04 style uprights and have the same thickness as the 05 style uprights. This custom machining would likely be very close to the cost of our kit (which would also give you far better bearings) and would likely be functional but of less strength / rigidity vs starting with the 05 style knuckles.
Hope this helps.
javid is offline   Reply With Quote
Old 04-02-2008, 12:49 PM   #14
Car: 2008 Pinarello FP5
tony
Tony its a close swap actually. Maybe a hair more work than a koni in a sti housing.............but you and I are thinking the same way......
mw
