Old 03-07-2008, 10:31 AM   #1
Default Whiteline KCA377 Rear Toe Lock Kit
Does anyone have any experience with this kit?
I'm under my car already and was going to install them since I have an alignment due next thursday.
I going for aggressive camber with zero toe all around, don't know if locking it in would be beneficial to me since I don't have adjustable control arms or do I have to have adjustable control arms in order to set the toe then lock it in?
Whiteline Instructions:
KCA377 toe-adjuster locking kit is designed to complement
cars already fitted with KTA107, KTA108 and KTA109
camber & toe adjustable control arms. The kit replaces the
OE or stock toe-adjuster, and eliminates the tendency of
the friction based factory adjuster to move and alter the
required toe settings. Particularly relevant for race or rally
vehicles or other high load applications. Can also be used
with some other types of adjustable control arms.
Check and adjust wheel alignment to desired settings using adjustable control arms. Use KTA107 for toe-adjustment,
and KTA108 or KTA109 for toe and camber adjustment.
BBKG79 is offline   Reply With Quote
Old 03-07-2008, 10:47 AM   #2
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Default Re: Whiteline KCA377 Rear Toe Lock Kit
Without even looking it up I'm betting it's just a nice thick bolt with no cam on it.
Oh, and stick with what you have now. if you don't have adjustable arms then you will need some other form of toe adjustment.
Old 03-07-2008, 10:56 AM   #3
[quote=Turninconcepts.com;1751962]Without even looking it up I'm betting it's just a nice thick bolt with no cam on it.
You are absolutely correct.
Thanks, less wrenching, less back ache Damn I need access to a lift
