Old 03-09-2008, 08:51 PM   #16
Car: RBP 05 2.5RS Wagon
Fav Mod: Group N Lateral Link Bushings
Default Re: Camber bolts slipping
Originally Posted by timeless420 View Post
It things still shift after trying your suggestions I'll go the the stock bolts again and throw on a set of plates when I put in springs and be done with it.
Note that people have slippage issues with camber plates as often as with camber bolts. Neither is foolproof.
williaty is offline   Reply With Quote
Old 03-09-2008, 09:14 PM   #17
Car: OBP STi
Fav Mod: really quick left foot & anything made my TIC
Williaty I rarely have heard of camber plates slipping compared to bolts. Do you have any proof or is this based on your own experience.
pharo is offline   Reply With Quote
Old 03-09-2008, 09:39 PM   #18
Not on my own experience, but on the fact that there have been enough threads about camber plates slipping on here and on NASIOC in the least couple of years to realize that it happens.
In fact, I'm pretty sure there's at least on active thread on here right now about it (it's not a thread about slippage though, it just came up). I can't for the life of me remember what it was actually about.
One of the gurus chimed in and said "yeah, we know, blue loctite is pretty much required for camber plates if you're going to track them".
Old 03-10-2008, 04:18 AM   #19
Car: 05 STi OBP
Fav Mod: Data Acq System
Crap, sounds like going to the stock bolts is what I need to do. Now, my understanding is that if the bolts are thicker than you get less camber adjustment. The only reason I got those ingals is because they give me -2deg. Do the H&R's have the same??
Also, how rough does the car get when slapping camber plates on it? Is it significant or is it about the same? I looked into getting a set of the RCE ones but then started worrying about my ride because it looked like the car would drive a lot rougher on the street.
MGizzle is offline   Reply With Quote
Old 03-10-2008, 06:31 AM   #20
OT stealth mod
Car: 06 obp sti
Fav Mod: Vodka injection.
Send a message via AIM to dailydriversti
I've had ingalls bolts for around 2 years now, only had the rear passenger side slip .10 just last year. Otherwise mine have stayed at the same -2.1 in the fronts, and -1.8 in the rears the whole time.
dailydriversti is offline   Reply With Quote
Old 03-10-2008, 07:54 AM   #21
Car: 05 STi OBP
Do you track your car a lot or at all? I never slip on the street either but right after my first session on the track I can visually see that the camber went to crap.
Old 03-10-2008, 09:03 AM   #22
I'd be really interested to know if the passenger side really moved or not. I've gotten numbers 0.2* different just by going to a different shop 2 blocks down the street (got curious and did it to compare one day).
Old 03-10-2008, 10:00 AM   #23
OT stealth mod
Car: 06 obp sti
The change was with the same shop, but yes, had a few autox's on that, and lots of daily fun on on ramps, but thats about it sadly enough
