Old 03-06-2008, 09:20 AM   #1
Car: 07 WR Blue STI
Default Best camber plate for my needs
Criteria
Must be able to achieve -3 camber with camber bolt and plate combined
Achieve as much caster as possible
Does not raise front ride height, preferably lowers.
Price is not a issue i believe in paying for quality
Must be compatible with stock springs, and TIC coilovers
gOt_rally? is offline   Reply With Quote
Old 03-06-2008, 09:35 AM   #2
Car: OBP STi
Fav Mod: really quick left foot & anything made my TIC
Default Re: Best camber plate for my needs
Well if you want to lower, I would say look at RCE lowering plates. They will definitely work with stock shocks. I see you want -3 front camber. Is that on stock shocks, because if so, that might be very difficult just due to the physical limitations.
I am not sure how the RCE plates fit with the TIC coilovers, but if I were going with TIC coilovers I would definitely look at the Vorshlag plates. But... Vorshlag plates will not work well with stock shocks. Honestly see what your end goals are, because trying to find optimal camber plates for a fixed perch solution and coilovers will land you with neither setup being at its best.
pharo is offline   Reply With Quote
Old 03-06-2008, 09:37 AM   #3
Car: 07 WR Blue STI
What im trying to do is run -3 camber with alk on stock spring this year then next year move up to the real deal and buy TIC's coils
Old 03-06-2008, 09:42 AM   #4
Car: OBP STi
I take it you are road racing, not autoxing (based on your alk)? I am in a similar situation so I am going with PDE camber plates. This will increase my ride height now, but once I get coilovers that won't be an issue.
If someone knows about the compatibility between RCE plates and c/o that could really make the decision easier for you. Their plates are excellent, the lowering plates will reduce ride height without the usual issues of lowering on stock shocks, and can be used with their Tarmac IIs.
Old 03-06-2008, 09:43 AM   #5
Fav Mod: Ohlins struts
I'm not sure if there is a camber plate available that would meet all of those goals.
- PDE plates would satisfy everything except that they raise the car.
- RCE non-lowering plates would satisfy everything except that they don't have separate caster adjustability.
- RCE lowering plates again don't have separate caster adjustability. They might allow the -3 degrees of camber adjustability you're looking for with the TIC coilovers. I'm not sure about that one. But they'll max out at around -2 to -2.2 degrees camber on the stock springs and struts.
- Vorshlag plates would be good but only with coilovers. I autocross against the guy who designed these and he whoops me every time, haha. Vorshlag has a reputation in the BMW world for making some durable, high quality parts.
Personally I've owned and used both the RCE non-lowering and lowering camber plates and can attest to their quality. They don't have separate caster adjustability, but for my purposes I'd still pick RCE's over anything else due to their design for maximum suspension travel. The way I understand it, it's the way they hold the strut rod higher than the spring (relative to other camber plates) that actually allows more bump travel before the struts are on the bump stops.
SWortham is offline   Reply With Quote
Old 03-06-2008, 09:53 AM   #6
Fav Mod: Motor Mounts
You can get -3 with just bolts...
Old 03-06-2008, 10:03 AM   #7
Car: 07 WR Blue STI
my whiteline bolts maxed out at -2
Old 03-06-2008, 10:11 AM   #8
You'll see certain suspension geometry advantages by using camber plates to max out camber rather than the bolts. Stretch has a thread about that around here somewhere. There are of course other advantages of using camber plates. Is it all worth $400? Well that's up to you.
Old 03-06-2008, 10:38 AM   #9
Car: 07 WR Blue STI
How much camber is possible with whiteline plates and bolts?
Cuz what I'm thinking is max out the camber for now and once i get the TIC's max out the caster as the TIC coilovers can almost reach -3 camber without plates
Old 03-06-2008, 11:02 AM   #10
Whiteline plates and camber bolts? That'd give you more than enough, right? Like 4 degrees or maybe more. Heck, if you're getting camber plates I'd throw away the camber bolts and use the stock bolts.
Old 03-06-2008, 11:28 AM   #11
TiC's coilovers work with the RCE camber plates, but I really dig the new Vorshlag design. It's got a bearing for the spring tophat with a fixed caster adjustment of roughly 1 degree over stock IIRC. The downside is that they're for coilovers only for the same reason: they have the nifty integrated spring tophat.
Other plates might offer a tiny bit more peak caster, if you really do want to place the emphasis on getting that. Search for the "free caster mod" though, if you haven't already.
For a stock strut setup, I wouldn't run anything that raises the car. That rules out PDE and others.
Actually, the stock struts have pretty different requirements than coilovers. I'd probably run Whiteline plates in that case, except you'll have to get the street version which isn't going to net much extra caster. I'd normally recommend RCE lowering plates for stock springs, but they apparently won't go to -3 camber due to the large diameter stock springs and fitment issues (the same reason Whiteline can't offer more caster on their street plates). I think they max out at 2.25 or so based on what I've read here.
So, I guess you have to choose which you want to optimize for. The best coilover plates (Vorshlag) won't work with your stock struts, and the best stock strut option (RCE) doesn't get you the alignment you really want. Whiteline is probably the best compromise, but it's still a compromise.
Old 03-06-2008, 11:44 AM   #12
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Answered you on nasioc, but have you considered putting a camber bolt in the bottom hole on the strut? You dial that one with the cam all the way out, and the top one with the cam all the way in.
Turninconcepts.com is online now   Reply With Quote
Old 03-06-2008, 01:40 PM   #13
Well that depends...bolts give you another option to work with. You can use bolts to gain clearance if you decide to run large rubber (i.e. 255+). I absoultly have to have bolts or it would be nearly impossible to run my 275's without huge arse spacers...especially in the rear...heck I alread run 8mm spacers in the rear...lol.
Old 03-06-2008, 05:40 PM   #14
Car: 07 WR Blue STI
How much camber will that net me give or take?
Old 03-06-2008, 07:16 PM   #15
Trader Rating: (53)
A Billion!!!! No seriously - don't know. it depends on the camber bolts you use, ride height, and all that junk.
Why is your heart so set on -3? are you just not getting enough grip with it on the current setup?
