Old 03-05-2008, 12:26 PM   #1
Fav Mod: Holy Hill ;)
Default should i use 06 struts
whats up guys;
ok here the deal i bot some rce black springs from a buddy and he gave me his stock 06 struts with the top hats. should i remove the springs and put them on my 04 struts or just install the 06 struts... what do you guys think thanks........
layza4sti is offline   Reply With Quote
Old 03-05-2008, 12:37 PM   #2
Car: 05 STi - Black
Fav Mod: No Lien
Default Re: should i use 06 struts
06 struts will not fit on your 04
Old 03-05-2008, 12:38 PM   #3
Car: WRB 04.5 WRX STi
Send a message via AIM to red5001
Well the 06 struts won't just bolt up to your 04. They have slight different tabs(mounts) that bolt to the knucle. You would need knuckles from an 05+. So I would just put the springs on the 04 sturts.
red5001 is offline   Reply With Quote
Old 03-05-2008, 01:11 PM   #4
sounds good i'll remove and install the springs on my 04 struts...
btw would there be any benefits for me to by the "tab mounts" to get the 06 struts to fit on my car??? only reason i ask is because my 04 struts are starting to clunk if you know what i mean.... thanks agian
Old 03-05-2008, 02:57 PM   #5
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
When you pull your 04's off pull the struts apart - regrease them, and cut the front bump stops.
Old 03-05-2008, 03:12 PM   #6
Car: '05 CGM STi
You can't just buy some part and make it work. You'd have to convert to '05 or newer hubs. ($$) And you want it to roll right? You'll need '05 or newer rims ($$). And this is being VERY simplistic about it, mind you.
$$$$$ Get the picture?
Old 03-05-2008, 03:15 PM   #7
The only way you can get 06 struts to fit is to install 05+ knuckles/hubs which has its benefits but cost a little. (look at the hub swap thread) Like above said re grease them and they should stop clunking.
Old 03-05-2008, 03:16 PM   #8
Car: Blue Slate 08 G37S
Fav Mod: None
Send a message via AIM to VtecSTI Send a message via MSN to VtecSTI Send a message via Yahoo to VtecSTI
Your struts will clunk NO MATTER what you do. You can take it to the dealership and replace them once every 3 months. I'm sure it's still in your warranty plan..i may be wrong though. How many miles do you have on your car now?
VtecSTI is online now   Reply With Quote
Old 03-05-2008, 03:31 PM   #9
rce springs come's with bump stop's, no need to cut the stock one's..
Old 03-05-2008, 03:32 PM   #10
lol, got it.. there no way i want to switch to the 05 hub, i didnt know that was needed....
Old 03-05-2008, 03:34 PM   #11
by by warranty thanks for the help guys, i'll just swap the spring's and call it a day.....
