Old 03-05-2008, 07:37 AM   #1
Default My service manual says I should replace my strut nuts after removing!
My 07' service manual states that the self-locking strut nuts, strut shaft nuts and tophat nuts need to be replaced after disassembling. I'm going to be replacing my springs soon and everyone I talk to says that the old nuts are fine to use. Whats up with this?
Turbopilot 2.5 is offline   Reply With Quote
Old 03-05-2008, 08:13 AM   #2
Default Re: My service manual says I should replace my strut nuts after removing!
they are fine. The warning is for lawyers and to sell more nuts...
aschen is offline   Reply With Quote
Old 03-05-2008, 09:27 AM   #3
Photography Mod
I haven't replaced them, and I have swapped out springs twice.
This may be the reason im taking them in to Subaru to be replaced too!
Old 03-05-2008, 09:56 AM   #4
Car: '04.5 STi
Fav Mod: ZZYZX
Eh, if you can get some new ones easy... get some new ones. They can't cost much.
If you're in a pinch or have to order some, I'm sure you can reuse them.
Old 03-05-2008, 02:00 PM   #5
Fav Mod: Motor Mounts
Its not required unless you eff the original bolts up.
