Old 02-27-2008, 11:35 AM   #16
Trader Rating: (50)
Default Re: Tein Struts + Cusco Rear Camber Plates - This Right?
Originally Posted by eXstasy View Post
Excuse the n00b question but, how does the stock rear top hat or GroupN top hat allow suspension to pivot?
Originally Posted by polyol View Post
My question is this...the stock top mounts have no pillow ball or any pivot point. How does the stock top mounts account for this movement? Just through the rubber deflecting alone?
There's actually quite a bit of movement from the rubber deflecting.
Old 02-27-2008, 01:55 PM   #17
Fav Mod: Motor Mounts
Got yeah. Well hopefully taking it for a spin around the block didnt hurt anything. Ill take the rears apart when I get home to see if I effed anything up.
Old 02-27-2008, 06:22 PM   #18
Trader Rating: (50)
I wouldn't worry about one spin around the block unless your block includes potholes and you bounced it off the curbs trying to hit every apex.
I will say though that it would be great for stepping the back end out until something broke.
edit: you know the more I think about it if that upper perch isn't hard bolted or stacked between the strut top and the pillow ball then most likely what will happen is the strut shaft will pivot, the upper perch will slip, and slap the spring and perch against the shaft. Not really catastrophic failure, but would be enough to scratch up the shaft and junk the damper.
Old 02-27-2008, 06:41 PM   #19
Took it off and the Cusco's are fine. Not even a scratch. Hopefully Tien can figure out a fix...if not anyone want a pair of rear rear mounts? Guess Im the guinne pig again.
Old 02-27-2008, 06:49 PM   #20
Trader Rating: (50)
If Tein doesn't come through do you have some calipers? If you do, and you're willing to work with us I may have a solution for depending on spring ID and stud OD at the top of the shaft.
Old 02-27-2008, 07:08 PM   #21
Car: 2008 Pinarello FP5
To the OP: if that doesnt work,...then let me know. I know you just bought those thinking this would work. I could find a home for them.
Either way, you will be fine. I think Clint might have something up his sleeve.
Myles
Old 02-27-2008, 07:16 PM   #22
Trader Rating: (50)
Myles
Heck, if my first idea doesn't work I've got my upper perches off the old zeals that might do the trick. They won't be pretty, but they'll do what they need to.
Old 02-27-2008, 10:13 PM   #23
Car: aspen 2005 wingless
holy crap, OP, you called Myles about this too?
I did the same thing, except mine were Tein Flex. LOL!
Old 02-27-2008, 11:50 PM   #24
How did you fix it or did you?
Old 02-27-2008, 11:53 PM   #25
I do have calipers. Ill measure them tomorrow. Also, if the Zeals fit...I dont care what they look like really...all I care about is functionality.
Old 06-09-2008, 02:34 PM   #26
Car: 05 WRX
i know this thread's a littttle old lol, but I'm going through the same dilemma right now with Noltec camber plates.. so did you just order the rear spring perches to fix the problem?
le wagon is offline   Reply With Quote
