Old 02-21-2008, 08:06 AM   #1
Car: '07wrbSTi
Fav Mod: Invidia G200
Default 2007 STi perrin rear sway bar problems
i searched and didn't find a conclusive answer to the following;
was there clearance problems with the charcoal canister aka the black box?
was there issues with the stout mounts vs. hardware supplied?
just looking for other members' experiences.
thaks guys!
kiwee is offline   Reply With Quote
Old 02-22-2008, 06:44 PM   #2
HowTo Contributor
Car: 06 STi
Default Re: 2007 STi perrin rear sway bar problems
I would also like to know the solution to this problem.
I installed my Perrin rear swaybar last year and noticed the replacement mount block that they supplied was not going to fit with the black box. I phoned Perrin and was told to just mount it up and it would work fine.....but it doesnt?
I am running the stock mount on the right side of the car with the Perrin mount on the left side.
jasv11 is offline   Reply With Quote
Old 02-24-2008, 11:41 AM   #3
STI PILOT
Fav Mod: MY GARAGE PERIOD
i have a perrin rear sway with stout mounts on my 07, had no issues putting em on. had to loosen the box to mount it but it went on with no problems.
Novtec1 is offline   Reply With Quote
Old 02-24-2008, 01:27 PM   #4
HowTo Contributor
Car: 06 STi
Where did the box mount bracket go, on top of the perrin mount or underneath the mount?
Can you take a picture of it back together, cause I'm obviously not seeing it correctly.
Old 02-24-2008, 08:56 PM   #5
STI PILOT
i'll get you pics tomorrow.
Old 04-08-2008, 03:27 AM   #6
Car: '07wrbSTi
month a half later and the stount mount ripped the nut & bolt from the subframe leaving a bibber hole in the sub-frame of the car. not happy.
getting fixed tonight.
installing cobb bars.
Old 04-08-2008, 01:35 PM   #7
Car: 06 Subaru imprezaSTi
Fav Mod: Prodrive
how are you fixing it? It's not the bar's fault one of the mount bolts came lose and all the force was put on one bolt. Same exact thing happened to me it's a bummer. I put the stock mount back on and welded it to the frame
steelgraySTi06 is offline   Reply With Quote
Old 04-08-2008, 03:21 PM   #8
Car: 07 SWP STi
Fav Mod: Perrin Exhaust
what box are we talking about? Are we talking about that blackish plastic box by the tow hook? Do the cobbs fit with the box there?
Dragicon is offline   Reply With Quote
Old 04-08-2008, 04:11 PM   #9
Fav Mod: Prodrive
yes that's the box the one one the rear passenger side of the car. It's the evap box for evaporated fuel emissions. the Cobb bars fit no problem. The mount is a pita because of the gas tank and the black box make it hard to get to the bolts holding the mount
Old 04-08-2008, 04:20 PM   #10
Car: 06 STI Charcoal
Fav Mod: UR POWER!
Alot of people having issues with the Perrin bars it seems.
HOLESHOT is offline   Reply With Quote
Old 04-08-2008, 05:16 PM   #11
Car: 07 SWP STi
Interesting, i always wondered what that stupid box was for.
