Old 02-21-2008, 03:13 PM   #31
Fav Mod: ProTune
Send a message via AIM to kigger012
Default Re: RCE v. prodrives v. cobb v. swift springs
I Would Say RCE Yellow!!! if u dont mine little stiffness!!!
i personally dont like soft springs... and i live in So. Cali. LA area!!!
kigger012 is offline   Reply With Quote
Old 02-21-2008, 04:07 PM   #32
Car: 06 SGM STi
Fav Mod: IWSTI sticker
Send a message via AIM to stidriver31
How stiff is rough?
stidriver31 is offline   Reply With Quote
Old 02-21-2008, 04:27 PM   #33
Car: 05 Subaru WRX STI Wh
Fav Mod: Invidia N1 catback, Helix DP
I made the mistake of going with S tech's and after reading these reviews I would have to say it still seems like the RCE Yellows are what im going to switch to. I like the stiffness of the springs but with the tein s-tech's I have to hold tight of the wheel or any pothole will make the car pull to either side.
Has anyone had issues out of any of these springs as far as the car pulling if you hit a bump. I mean it pulls bad enough to where I have both hands on the wheel at all times. Alignment is straight but springs have killed the overall feel of the car.
speedjunkie is offline   Reply With Quote
Old 02-21-2008, 05:42 PM   #34
Staying eThug'd out
take a look at my comparison with RCE vs. Prodrive springs:
Prodrive vs. RCE - SoCalSubies Forums
This is with the v1 RCE yellow springs so I don't know how much more they've changed.
In my opinion, I like the Prodrive springs but it is a huge possibility that I will remove them and put the stock springs back on as there really isn't a justifiable difference between the two.
Old 02-22-2008, 09:00 AM   #35
Car: 05 STI OB
Fav Mod: RCE Blacks
Originally Posted by stidriver31 View Post
how rough are the blacks
According to RCE the black (regular guy) springs have roughly 10% stiffer rates than the pinks. They also have similar rates to the yellows and are intended for DD and weekend track days, but have less drop. Since I don't want may car to be anymore of a snowplow than it already is, I chose the blacks. If it wasn't for that, I would have liked to try the yellows.
As far as the pot hole/ S Tech bouncing Speedjunkie experienced.... I slso experienced that. You are absoutly right, two hands on the wheel, or the car was on the way out of the lane. (Not good for my 100 mile per day commute.) The zip tie seat repair in conjunction with the RCE blacks definitely helped a lot. I did both at the same time, so I can't say what made the most difference.
PIGSTI13 is offline   Reply With Quote
Old 03-10-2008, 05:38 PM   #36
Car: WR Blue 04 STi
Send a message via AIM to Rezidoo
hey guys quick question....with RCE yellows...would you get the RCE lowering camber plates to give it a lower drop or is that too much drop or is that even a good idea???
Rezidoo is offline   Reply With Quote
Old 03-20-2008, 08:07 PM   #37
Hey Parker,
Prodrive claims a 20mm drop all around (roughly about a inch) but some retailers claim its more of a 10mm Front and 5mm Rear, perhaps everyone has a different way of looking at it. Can you verify which one is more accurate?
t30wrx is offline   Reply With Quote
Old 03-20-2008, 08:56 PM   #38
Staying eThug'd out
Originally Posted by t30wrx View Post
Hey Parker,
not horribly sure because I don't have them on my car anymore. i'd say the drop was very conservative yet noticeable compared to stock but actual numbers I can't verify.
Old 03-21-2008, 12:04 PM   #39
Car: 07 STI OBP
Fav Mod: NUR SPEC R, 57maximum t/a,300 shot nitrous, dual carb, ITB,
how much drop is the yellows? and who makes the lowest springs?
Old 03-21-2008, 01:07 PM   #40
Car: 2008 Pinarello FP5
The drop is about 23mm front and 20mm rear for RCE Yellow springs
If you value performance and ride quality, you don't want the lowest springs.
- Andrew
Old 03-21-2008, 04:24 PM   #41
Car: 07 STI OBP
- Andrew
i dont want the lowest drop but i do want my car pretty low. i posted a thread about RSR ti2000's and one person said its trash and 2 ppl said its good.
Old 03-21-2008, 05:56 PM   #42
D_STI is offline   Reply With Quote
Old 03-21-2008, 07:39 PM   #43
It would've been nice if the STI came stock like the Prodrive WR1 STI but cost has to be cut somewhere I guess. Anyhow, with help from different STI drivers and Venders I decided to install Prodrive springs after trying H&Rs, and Swifts. My conclusion with H&Rs is that the spring seems too soft for the car... I catch myself hitting the bumpstop too many times when driving down a mildly crappy road and the Swifts where too stiff for me even though the spring rates almost the same with other favored springs like Blacks, Pinks, etc.. These linear rated springs are really best suited for smooth roads and people that really track where they'd need the confident feedback right away.
