Old 03-14-2008, 03:52 PM   #16
Default Re: mild suspension setup, thoughts?
Originally Posted by Parker View Post
your struts will eventually clunk or blow with aftermarket springs...at least from my observations. ohlins i've heard are great struts, I just don't have the coin for them. i'd look into the Bilsteins too.
the springs I want r RCE blacks btw. Don't the bilsteins only work with there springs? I guess Ill eventually need the ohlins, correct?
Rallyon is offline   Reply With Quote
Old 03-14-2008, 05:12 PM   #17
Photography Mod
the Blacks are a drop spring as well and are stiffer than the stock spring I believe. these two factors could assist in early strut problems but others can verify that.
IMO, you don't "need" the ohlins but they're good struts from what I hear. and i thought I read somewhere that you could use the bilstein struts with other springs as long as you purchase the proper strut for your application.
