Old 01-19-2008, 02:15 AM   #46
Default Re: Theory on bobblehead and fixing the bouncy seat
Originally Posted by Turninconcepts.com View Post
I've had an idea bouncing around in my head for a while. Some book I read - don't remember which one - mentioned using memory foam for the seat foam. Basically, that stuff that the swedish mattresses they sell in the mall is made of.
I've been searching a few places such as homebuilt airplane suppliers, but the stuff isn't really in the size I want. If anyone knows of a good source, and if we have someone who's good at car interiors (maybe one in the same guy) I would think this would help since it's a self damping material.
I was thinking the same thing, and I'd probably insert some memory foam if I remove the seat springs altogether. Here's what I'd buy: just some Overstock.com memory foam pillows:
Serta Memory Foam Contour Pillows (Set of 2) : Bedding & Bath from Overstock.com
Old 01-27-2008, 01:12 PM   #47
Car: silver 04 wrx sti
Fav Mod: tic coilovers
Originally Posted by howboutthemapplz View Post
i will do this soon, i will zip tie the springs to the bars below it like sidewayssteve. this has to be FTW. especially being 6'5''. ill gain a tad of head room. lower with better side support. and i only weight 165. i am sitting ontop of it. When i drive like a deek, i just slide around. lol. i wont really know how it is until spring(ish) because i am most likely going to be in active duty with the Air Force.
Thanks for the great ideas!!
Try unzipping the back seat cover a bit and stuffing some strips of foam on top of the seat bolster. I got a lot more lateral support for my skinny backside.
steve
slidewaysteve is offline   Reply With Quote
Old 02-21-2008, 07:30 AM   #48
Car: 04 Black STI
Send a message via AIM to reid-o Send a message via Yahoo to reid-o
Originally Posted by fullerton View Post
Stretch- Someone (slidewaysteve) already tried a version that is between your idea and mine. While they did remove the springs from the equation (my idea), they lowered the seating height also (your idea...kinda).
How-to Cure Bobblehead for cheap
Maybe you could use slidewaysteve's bar idea and attach your "dampers" to it.
I would like to try this, as it's not quite as permanent as cutting the springs.
However, I can't really tell, but it looks like you've drilled and screwed your added bars to the existing cross bars (are those bolts at the front)?
Is it important that I secure the added bars? Or do you just have it zip tied to the springs and held by tension?
reid-o is offline   Reply With Quote
Old 02-21-2008, 09:55 AM   #49
Fav Mod: Ohlins struts
What about removing the springs from the seat and in their place install some firm, high resilient foam that simply sits on top of those bars? That way you'd get more cushion, and no more bounce.
Perhaps the "Firm" foam from this site would do...
Custom molded flexible high resilient and viscoelastic (memory) polyurethane foam - Bryn Hill Industries
I suppose some sort of platform for the foam to sit on may be needed.
SWortham is offline   Reply With Quote
Old 02-21-2008, 10:12 AM   #50
abracious
Fav Mod: Track time
Wouldn't only using the two outside bars achieve the same effect? In essence, all you are doing is moving the mounting point of the bars lower.
Plus, with that setup, I wonder if you simply sink down until you hit the black bars, at which point you weight is pushing them downwards, making them lose contact with the seats two polished bars.
Old 02-21-2008, 11:27 AM   #51
Car: 04 Black STI
That's where my question derived from. I assume that he's drilled into the polished bars and attached those bolts to make sure that they maintain contact.
Old 02-21-2008, 11:45 AM   #52
abracious
Fav Mod: Track time
If that was his reason, he failed to follow through since the rear is loose.
Old 02-21-2008, 11:47 AM   #53
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Originally Posted by RaceComp Engineering View Post
Clint/Tony you just made me think of a friend's parents who bought one of those beds and the cat pisses on like on part and they might be chucking it
Nuts
I have one (Not a mattress but a mattress pad, to go over a regular mattress) and my cat pissed on it. I refuse to use it but it's just hanging out in my closet. Maybe ill try and use a piece of it.
Old 02-25-2008, 09:04 PM   #54
Fav Mod: alcantara...everything!
If it is good enough for NASA, it is good enough for us I believe I know where I can find some of it. Call you tomorrow afternoon.
Old 03-09-2008, 03:11 PM   #55
Car: '05 Blue/Gold
Fav Mod: FPGreen & Track time
Originally Posted by CKLewis View Post
can you guys update with with results once you remove/stretch the springs? sounds like leibo had good luck doing this.
I just did this progressively over the past few days. On the lower portion of the seat I removed the middle of the 3 springs, then ziptied the rear one to the solid metal bar. The result is fantastic, and I am definetly sitting lower.
On the back portion of the seat I removed all of the springs except the smaller upper one. The springs simply pop out with force, so no cutting is necessary. Overall the seating position feels WAY better and finally holds me in good.
When I first started removing the springs, I removed the middle lower one first. Drove to work and it felt great. I felt it could have improved more, and removed the remainder of the aforementioned springs. I'll drive it to work again tommorow and see how it feels, moreover, test sitting right now feels darn good. Thanks to those that hypothesized this.
royalsti is offline   Reply With Quote
Old 04-06-2008, 07:14 PM   #56
Car: 05 STU STi White/Gol
Fav Mod: Suspension!
Send a message via ICQ to wrxtc Send a message via AIM to wrxtc Send a message via MSN to wrxtc Send a message via Yahoo to wrxtc
I have one of these sitting on top of my seat, huge improvement.
wrxtc is offline   Reply With Quote
Old 04-06-2008, 08:02 PM   #57
I will try the spring deal. I am still thinking up a way to get additional foam in there w/o distorting the original seat pattern, etc.
Old 04-07-2008, 08:55 AM   #58
Fav Mod: Driving School / Trunk swap (no attention ftw)
^^ maybe inserting some of that foam above the springs, once they are pulled down? Just have to find a cheaper place to get nice memory-foam.
J
mgsm666 is offline   Reply With Quote
Old 04-07-2008, 02:35 PM   #59
Fav Mod: TiC AST Coilovers!!!
Trader Rating: (88)
for the skinny guys, use some pipe insulation foam in a strip on the right and left rib bolster to make the seats narrower to hold better.
I also pulled the lower and back springs outwards to let me sit deeper, but I still get bobble
WC LATHE WERKS is offline   Reply With Quote
Old 04-07-2008, 03:31 PM   #60
Car: 04 Black STI
I pulled the springs and stretched the crap out of them as well.
It made a difference but I do still get some bobble.
What's improved is my reaction to large gaping holes on freeways. Before, I would actually put my right foot against the foot rest and brace for the impact consequent liftoff like I was in a rollercoaster. Now I just sort of do a quick breath and the car takes it. I still move a bit but not that bad.
Sadly, pulling the lower springs makes you sit lower but not by much.
Pulling the back springs really made a difference.
MAKE SURE you pull the back springs evenly and test them out before driving off.
I pulled mine a tad unevenly at first and then I drove off for work. I had the meanest pain in my back after sitting crooked for a good 45 minutes.
Since the airbag is in the top half, would it be possible to make a seatcover with the foam inside just for the lower portion of the seat wrapped in a similar material, like a pullover for your ass?
Just a thought.....
