Old 01-17-2008, 06:25 AM   #16
STI Guru
Fav Mod: grip.
Default Re: Theory on bobblehead and fixing the bouncy seat
Originally Posted by RaceComp Engineering View Post
The place that this is WORSE is on the NJ turnpike from exit 5 to exit 7. There is a rimple in the road that makes these cars just bounce , bounce, bounce. CONSTANTLY. Its probably under the asphault from YEARS ago when it was concrete blocks. But as you said......as the car reacts , you react, the seat reacts THEN, it starts all over. STOCK shocks are the worse with stock springs on that stretch of road. I did my first JDMpinks comparison there and later others found that area and couldnt believe that the road was that bad.
Same thing in maryland on RT 97 going NORTH after you pass under RT 100. You want to test the seat theory someplace?..THATS the place for us local MD guys. Same thing as in NJ on the turnpike..constant bounce.
Myles
i know that section of 97 actually... and 202 between malvern and king of prussia up here is the same way as the turnpike discription. wavy lol
Old 01-17-2008, 08:21 AM   #17
Teh Other White Meat
Trader Rating: (22)
I'm interested in #4. This would be my last stop before new seats. I have a sore left knee the day after track and autox because i'm bracing myself using the dead pedal so much.
Originally Posted by fullerton View Post
That has nothing on 355 in the west suburbs of chicago. From 88 to 290, that road is bounce after bounce.
I can't imagine having boobs on that stretch.
It's fun to have a set in the passenger seat. It's hard to keep your eyes on the road though. Bobblehead is now officially a liablility!
Old 01-17-2008, 09:46 AM   #18
Stretch- Someone (slidewaysteve) already tried a version that is between your idea and mine. While they did remove the springs from the equation (my idea), they lowered the seating height also (your idea...kinda).
That's not really what I had in mind for #4. The goal is not to pull the springs down- it's just a byproduct of my idea. The real idea is to reduce the spring frequency by adding a load that pulls in the opposite direction. This will still allow the seat to have a spring motion, except the seat will think it has a 400lb man in it instead of a 200lb man. This lowers the spring frequency of the seat which I hope will make it more comfortable.
Old 01-17-2008, 09:48 AM   #19
STI Guru
Fav Mod: grip.
what about removing that spring completely with some metal shears? lol
Old 01-17-2008, 11:28 AM   #20
abracious
Fav Mod: Track time
I know you're joking, but that would cause other problems.
Old 01-17-2008, 11:31 AM   #21
abracious
Fav Mod: Track time
Hence the "your idea...KINDA" disclaimer. I am just suggesting that you could use the bars that are parallel to the car's direction of travel to secure your "opposite direction load".
Old 01-17-2008, 12:24 PM   #22
Ah, gotchya gotchya.
Old 01-17-2008, 02:24 PM   #23
Trader Rating: (14)
So does bottom of the seat(white cloth) actually touch the springs when weight is applied? If so maybe cutting the middle spring would help some...total seat newb here
Has anyone confirmed that seats out of all year STis are the same? I sat in a passenger side seat of a friend's 06 STi and it felt smaller and less bouncy than my 04 larger driver's side seat. I was the second person to tell him that too.
blindfold is online now   Reply With Quote
Old 01-17-2008, 03:19 PM   #24
abracious
Fav Mod: Track time
iirc boon, the springs always touch the seat bottom.
Old 01-17-2008, 05:49 PM   #25
Car: 05 Subaru WRX STi
Rather than removing all of the springs, you could either stretch them out or remove one or two of them leaving the rest in place. This would also lower the overall spring rate of the seat but you wouldn't have to rig up bungy cords to the bottom.
I removed a spring from the back of my seat and it made a huge difference! It was always SO stiff on my lower back and in certain situations i think adds to the "bobble head". An example is when your rear wheels go over a bad bump and since your seat in reclined you get a portion of that force pushing up through the back of the seat as well. Removing a spring from the back not only made the seat more comfortable, but it also helped to give that "sitting in the seat, not on it" feeling, while at the same time taking some of the bounce out of the ride. I have been meaning to do this to the seat bottom as well and I am confindent that the combination of the two will provide a drastically different riding seat (that will also hold in the corners better).
mtskibum16 is offline   Reply With Quote
Old 01-17-2008, 06:04 PM   #26
Wow, that's an even better idea!!! Good work. I am going to do just that- I'll remove the middle spring, then put a piece of thin aluminum accross to bridge the other two springs together. It's a brilliant idea and exactly what I was hoping to accomplish!
Old 01-17-2008, 06:34 PM   #27
Fav Mod: 11.5:1 Q-Rack
As suggested above, I simply put vice grips on them and stretched them out about 25% about 2 years ago. Now I have nearly no bouncing.
LeiboWRX is offline   Reply With Quote
Old 01-17-2008, 08:10 PM   #28
Car: 07 STI UGM
Fav Mod: Boob jobs
...then put a piece of thin aluminum accross to bridge the other two springs together....
Ahh, and there is the light weight solution I've been looking for,
Lurker is offline   Reply With Quote
Old 01-18-2008, 03:10 AM   #29
Car: 2008 Pinarello FP5
I will try this on the Legacy.
mw
Old 01-18-2008, 05:07 AM   #30
I can't seem to find any pic tutorials involving modifying the stock seats. Kindly post something if deciding to try one of these solutions. Thanks.
Boxer is offline   Reply With Quote
