Old 01-07-2008, 12:03 PM   #16
Fav Mod: 57fs
Default Re: Cobb Sway Bars?? Anyone have them? Whats the difference?
I just always saw rust. Depth of it is hard to tell unless crawling under the car and physically checking it.
wrxcelration is offline   Reply With Quote
Old 01-07-2008, 12:08 PM   #17
abracious
Fav Mod: Track time
I highly doubt it would be anyhting more than surface rust. If you have a part that is 27mm thick and has rusted to the point of failure, I have a feeling that is the least of your troubles.
Old 01-07-2008, 01:19 PM   #18
Fav Mod: 57fs
O I completely understand. Just the sight of rust always concerns me
Old 01-07-2008, 04:45 PM   #19
wdb
dances with roads
Anyone considering Cobb bars should also consider Hotchkis. Same construction (Hotchkis makes the swaybars Cobb sells), more options in terms of available sizes, and quite often much lower prices can be found.
Old 01-07-2008, 04:48 PM   #20
Car: 06 subaru wrx sti
Fav Mod: royal purple
i have the cobbs set at the middle and do "spirited driving" at the canyons and it can get tail happy. also depends on the tires. i would say middle is your best bet. unless you want to say " oh SH!T" going around the corners. it scares me sometimes when the tail swings out.
disturbed1 is offline   Reply With Quote
Old 01-27-2008, 10:50 PM   #21
Car: 07 Subaru WRX STi
newbie here. Im lookin @ Cobb sway bars now. I did some research but im still confusing between the Std and the Adj one??? Im using this car 90% DD, which one u guys think will fit me the best???
Slow.STi is offline   Reply With Quote
Old 02-04-2008, 02:34 PM   #22
Fav Mod: 255's ftmfw
Send a message via AIM to sticop
^^ 2x ^^
sticop is offline   Reply With Quote
Old 02-04-2008, 03:56 PM   #23
abracious
Fav Mod: Track time
I'd go adj. Who knows what's in your future.
Old 02-10-2008, 10:17 AM   #24
Car: 07 UGM STi
Fav Mod: Gabe's stage 1 flash
Send a message via AIM to SubieDave
^^I would agree with that. If you don't like one setting, there's always two more..or at least one!
SubieDave is offline   Reply With Quote
Old 02-11-2008, 08:35 AM   #25
Car: blue 05 wrx sti
where is the standard COBB setting in comparison to the adjustable ones, soft, mid or hard. The car is a strict daily aggresive driver on not so perfect NYC roads and i don't have time to be making adjustments. thanks in advance.
pkradgreek is offline   Reply With Quote
Old 02-11-2008, 02:51 PM   #26
Non-Reformed Meth Addict
Car: '06 WRB
I run my rear bar on the middle setting. Tried it on the soft setting for a few Auto-x runs and it understeered like a garbage truck. Middle setting is pretty neutral for me on RE01Rs with 0 toe all around.
Old 06-01-2008, 11:45 PM   #27
I think the biggest deciding factor is how much sway do you want? The COBBs are hollow, so they are less stiff per diameter than a solid WL bar. With stiffer springs, less bar is necessary (as a generalization). The opposite is true (again, a generalization).
since WL is stiffer than Cobb w/ the same diameter, but can u actually FEEL the different between those 2 when u drive or not?
