Old 06-07-2004, 02:36 PM   #1
IWSTI Addict since: Apr 2004
The back of my STi feels wobbly when entering those circular freeway entrances fast. It feels like the back is going to slip out when I travel at around 50mph. This feeling goes away when I set the DCCD to the second green from the bottom. Does anyone else get that wobbly feeling? Are there any mods that can fix that?
na-STi is offline   Reply With Quote
Old 06-07-2004, 04:00 PM   #2
IWSTI Addict since: Jun 2003
Whiteline steering rack bushings factored in a great deal to stabilize some "wobbliness" straigh-line or otherwise. and only 30$ too.
Olappa
olappa is offline   Reply With Quote
Old 06-12-2004, 03:51 PM   #3
Car: Solo II, WRC
IWSTI Addict since: Oct 2002
Send a message via AIM to CloNeGTS
Check your tire presssures first. I am chasing down a similar problem which has been present for some time, regardless of changes like the Whileline steering rack bushings, Espelir GT springs and soon-to-come alignment. Honestly, I think the problem is in the tires for me....might be for you.
CloNeGTS is offline   Reply With Quote
Old 06-12-2004, 09:06 PM   #4
Obviously you have power on, otherwise the DCCD wouldn't affect anything - so how much throttle are you throwing at it? When you say "wobbly" - what do you mean? Loose (does it actually slide?), mushy, what? And, how hard is the corner - is it rated for 15 mph, 30, or??
A 30 mph on-ramp taken at 50 should give you ZERO problems, just g-force. You should start with slight understeer giving way to slight oversteer if you keep the throttle buried, but it'll pull you through very, very nicely.
Old 06-12-2004, 09:13 PM   #5
Addendum - I just thought of something. Are you by any chance having to grab another gear in the middle of this particular corner? A gear shift, or even a slight throttle lift, can and will induce some wicked oversteer unti you re-bury the throttle. These things act a lot like old Porsches in this regard. Just a thought.
